| Class D Switching Power Amplifiers and Power D/A conversion |
#371 |
#372 | |
Or you can add a soft-start bypass to the turn-on switch. That's easier and is better for your caps and amps. Again, circuit diagrams are available around the web. -dr_vega |
#373 | |
Looking at the picture Arjen posted on ebay I can see that there are windings that pass through the hole and have close contact with the toroid. And there are windings that pass the inside of the core on top of other windings and do not make contact with the inside of the core. This I would call second layer. The question on the knitting pattern is now, do first and second layer alternate while going around the toroid or is there a first layer wound around 360 degrees of the core and then another layer added going around the core a second time. Even though I am not sure I fully understood you answer, the fact that you are able to free up 30 degree of coverage would mean that first and second layer alternate. Do your cores resemble the picture at ebay? I have a hard time to believe that with this wire gauge you could press the windings together such that 30 degrees are left open. Cheers |
#374 |
Gents,
I fixed my ground issue, and how SWEET it is. Very, very nice, works great. I ordered my 2nd board. You're all invited for a beer and a listening session. |
#375 | |
-dr_vega |
#376 |
Audio1st,
I received the Meanwell 24V / 6A PS today. When I connected it to the TK2050 board by itself, everything was working fine at the set voltage. But when I added the 2-6800uf power caps to the screw-in terms, the voltage dropped to about 6 volts. Any way to fix this? Thanks in advance. /j |
#377 |
Nisbeth and Cheric,
both of your issues can be solved with a soft start circuit that slowly fills your caps before the amp comes on. The SMPS sees a short circuit when a large current flows to fill the caps and goes down in safe mode delivering only ~5V. Attached you find a sketch of my poor man's version of a soft start circuit. I use it with the exact Mean Well SMPS and the sure board and it works. I have roughly 20mF near the amp. |
#378 |
ElFishi,
My biggest problem is with the power caps. Every time I added a power cap, I would loose a channel (CH1). Only with the MW 24v/6a that the voltage would drop, the other three different power supplies stayed stable, just no channel one. |
#379 |
I can explain the drop in the voltage of the Mean Well SMPS when it sees to much capacitance across its output. The same happens with mine. That's why I added the relay.
I cannot explain you losing a channel with the caps. I am at a loss what your problem is there. |
#380 |
I agree with ElFishi, my power supply didn't like the extra capacitors so I simply only added an extra 3,300uF. I also have no idea why you lose one channel?
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 11:41 AM |
| Page generated in 0.10768 seconds (71.60% PHP - 28.40% MySQL) with 11 queries |
