Sure Electronics New Tripath Board tc2000+tp2050 - Page 233 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th December 2013, 12:29 AM   #2321
Originally Posted by Apachestar View Post
I remounted the fan with some elastic material between it and the housing. The noise went down a lot, but still it's loud. My old sure PS (which was MeanWeil) and amp did not have the fan come on until the temp hit a certain limit. I'd like to do the again, as I have the amp near a chair and you hear the fans when no music is playing. Any ideas how to have the circuit kick in when the temp hits say 100F?
I know what you mean as I never seem the fan on with my MW power supplies.
You can get two of that passive heatsink or a temperature active fan like this one
Old 28th December 2013, 12:43 AM   #2322
The links do not work. I do not know if my old MW ever come on. I might try running this without any fan, and see if the temp overload kicks in. The PS sits in a well ventilated space with the sure amp pushing minimal air via its fan. Then, if its cutting out I could add a temp active fan (ill google those and find one, I'm sure. ). Thanks for the help.
Old 5th February 2014, 07:57 PM   #2324
cogitech's Avatar
Originally Posted by Virpz View Post
Ok, I am going to ressurect this thread....
What I have done with this board ( Ver. AB32186V220 ) :
Awesome, but I have some questions.
1- Replaced all electrolytic capacitors with panasonic FM and FC.
OK. Makes sense.
2- Replaced inputs caps with 2.2uF mundorf ( keep legs short ) .
Yes, still with you.
3- Added 550uF electrolytic to the tc2000 .
OK, I'm lost. Can you please state specifically what you did, and/or show a pic?
4- Added a separated board for the output filter;
- Low pass Rifa PHE 426 ( I love these caps ) .47uF and baked air cored Litz inductors of 10uH ( Will replace inductors with wurth 7447709100 ) .
- High pass Rifa 0.56uF and MOX 4.7 Ohms 4W .
Perhaps this would be best for me to do later
5- These new boards even have the pads for the snubber caps and resistors, Go for 300/330pF and for the resistor go for 20 Ohms 1/4W
Again, if you could provide precise instructions and/or pics, please?
6- Inverted the fan for better air flow.
7- provided a case, alps pot and all the wiring was done in Litz because I had these around and someone said that I could avoid proximity effects by using it.
Nice job!
Old 14th February 2014, 11:02 AM   #2325
hello.
I have a muse dt-50 2x50W amplifier that uses the chip TC2000 + TP2050, and one of the two channels fail, only sounds clicking the other works with normally. Would they tell me why this happen? the board is this:
60RFNDXzk3NzI http://museaudio.com/photo/album/usaFeBhNZm_% @. jpg
the board has a pin ISP +5 v GND RXD TXD, someone has to configuration parameters?
Thank you very much!
Old 15th February 2014, 04:36 PM   #2326
Originally Posted by goldenayo View Post
hello.
I meant to say one of the two "speaker" channels.
Old 21st April 2014, 08:22 AM   #2327
niamex is offline niamex  Bulgaria
Hi there,
Unfortunately the version I am planning to get for tweaking seams different from these discussed here. Will you please comment that one - TK2050 50W 50W Class T HiFi Stereo Audio Digital Amplifier Board DC 12V Voltage | eBay
Thanks in advance,
Ignat
Old 6th August 2014, 02:48 PM   #2328
clm811 is offline clm811  United States
clm811's Avatar
Default Getting high pitch tone!
I have a Sure model AA-AB32186 board, and while desoldering the input caps,
I accidentally knocked out R1 and R2 (22k). I intended to replace input SMT electrolytics with regular film caps.
These R1 /R2 resistors go from input to ground and appear to set the input impedance of the amp.
Measuring across each RCA jack then, I got about 75k ohms on my ohmmeter.
I hooked up a speaker to the outputs (no input) and the green light came on (good), but when I put a 22k ohm(1/8 watt) resistor across the input to ground (with or without input connected) I get a high pitch tone (oscillation?), and the green light doesn't come on.
I need a schematic for the input circuit of the AA-AB32186, to determine if the 22k shunt resistors go before or after the input caps (can't tell from the pcb traces).
Thanks in advance!
-Chas
Old 6th August 2014, 05:03 PM   #2329
clm811's Avatar
Default fixed it
It turns out that the cap goes after the shunt resistor, and now the noise is gone.
Still would like the schematic for the Sure model AA-AB32186...
Old 6th August 2014, 05:17 PM   #2330
Malefoda's Avatar
Send a message via MSN to Malefoda
Nice to keep us informed
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright 1999-2017 diyAudio
