Sure Electronics New Tripath Board tc2000+tp2050 - Page 229 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 5th May 2012, 09:13 PM   #2281
v-bro is offline v-bro  Netherlands
v-bro's Avatar
It can't hurt but you should not expect any miracles from it. If it is to solve problems you will probably discover this wasn't the solution.
Extension shaft kits are not that expensive... Some nice parts at the bottom of this page:
potentiometers, switches and attenuators homepage
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 7th May 2012, 05:25 PM   #2282
My experience with these boards is rather different. I purchased mine from Parts Express. The price is a little higher, but the boards work on arrival and keep on working. I suspect that Sure provides a better product to Parts Express than they ship direct.
If changing the output filter network of any class D amplifier, it is somewhat important to use inductors and capacitors of the proper type (usually composite core toroid, wound with appropriate number of turns of 16 ga. solid wire) and high quality non-polar electrolytics at the very least. This is a tricky business on surface mount products like the Sure boards. The TK2050 board filters are designed for 4 ohms output impedance. If driving > 4 ohms, there will be changes (small, but possibly noticeable to golden eared listeners) in the frequency response curve at higher frequencies, in addition to decreased output power. This design as implemented by Sure is stable at 8 ohms, but I would be very cautious trying to use this at any greater impedance.
Old 7th May 2012, 05:33 PM   #2283
PS The first reports are in on the new TI and IR based boards, and these seem to have similar quality of sound to the earlier Tripath designs.
I strongly suspect that Tripath devices will be available indefinitely. The designs were sold to another semiconductor company, which could license them to anyone with a fab. Also, since a lot of these products are from China (pretty lax about intellectual property), I suspect that some of the chips being supplied are 'knock offs', although they seem to work as well as the originals, if that is so.
I have heard that even though some of TDA 749X boards have less than ideal output response due to some trickiness in designing output filters for these chips, the boards still sound good.
The higher power chips from IR and TI do require relatively high voltage power supplies, which, even in SMPS form, typically cost 1-3 X the cost of the amplifier board. Still a bargain, at about $300-350 for 500-600 clean watts. However, not for beginners--these power supplies and amp boards can easily fry both the experimenter and his/her attached transducers!
Old 7th May 2012, 06:21 PM   #2284
v-bro's Avatar
What temp is the TP2050 chip running at in your Partsexpress Sure board? And at what voltage are you using it?
Old 23rd May 2012, 09:47 PM   #2285
bezedache's Avatar
I possess a card AA-AB32181 modify with your precious advice
and I wonder if the AA-AB32186 is identical. Because I can not find the shema
Thank you
Old 1st June 2012, 01:28 PM   #2286
Hi all Tripath enthusiasts
to make a long story short, I use the TK2050 from sure and spent a long time improving it are at least trying.
I use a 30V SMPS to power it and out of curiosity, I connected a scope at the speaker output. I have a huge overshoot with several bounces, the highest peak is over 4V above the 30V power supply voltage.
I noticed that TRIPATH application provisions a snubber right before the two main filter inductors. Sure did not provision this space on the layout. The two inductors are directly connected to the TP2050 without snubber. I tried to add the recommended one (20 Ohm + 330 pF) and noticed a huge increase it heat (both on heatsink and inductors) confirmed by the current measure with no modulation : before adding the snubber, 270 mA; after adding it 380 mA
The overshoot is sligthly improved, still many bounces, but amplitude decreased by 2. This extra heating seems abnormal to me.
The only change to the original Sure board is the output inductors : I changed them to some 7A WURTH, still surface mount
The most important measurement is this the frequency of this overshoot : the bad square wave with overshoot is around 700 KHz, but the overshoot seems to be around 4 MHz (plus or minus a few hundred KHz, my scope is old and the trace a bit fuzzy !)
Did you guys already monitor the output ?
Do you see a quite good square wave, or do you have overshoots ?
Do I have this because this is my WURTH coils resonance frequency interfering ? Or is it a PCB layout problem from SURE ?
Any idea is welcome
thanks
Old 5th June 2012, 09:39 PM   #2287
Send a message via MSN to McPoppes Send a message via Yahoo to McPoppes
Default TDA7498
So i didn't want to read the whole thread since its quite long, but i just bought this 4x100w amp from sure electronics based on the TDA7498 tripath chip, and i've tested it with a 24v dc HP-laptop power suply, and so far it sounds great, but it lags a bit on the kick and bass when the volume goes up, the reason for that ofcause, is that it needs more voltage. Anyways, i read in another thread, that the TDA7498 chip, is a kinda discount tripath chip compared to other chips, but since i havent heard any of the chips dicussed in the other thread i cant tell weather its discount or not, and if so, where i should by my next tripath amp, for future projects? (i'm going to build a festival audiosystem, where i am using the sure amp.)
link to the other thread Distortion Tests - HifimeDIY T2 / LJM L20D / SURE TDA7498
Old 4th September 2012, 04:26 PM   #2288
Can this board be safely run off 36v (nominal) from 3x 12v in series? When fully charged they would be around 39v right...?
Old 4th September 2012, 09:54 PM   #2289
yes its max input is 39 volt
Old 5th September 2012, 03:09 PM   #2290
But will it overheat or blow up? I read back a few pages and it seems like 27v is about the reasonable limits.......? This is for a portable setup.
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright 1999-2017 diyAudio
