Sure Electronics New Tripath Board tc2000+tp2050 - Page 188 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd November 2010, 12:35 PM   #1871
ranger3 is offline ranger3  United States
Default SPST Automotive Round Rocker Switch w/Blue LED 12V
Quick question.
I have the Parts-Express SPST Automotive Round Rocker Switch w/Blue LED 12V (060-770)
It has 3 connectors on it. (+, A, Ground). How do I wire this for my Sure board? Also, since the LED is for 12V, I will be using 30V, I believe I will need to put a resistor on this.
Could someone explain to this newbie how to wire this up with a resistor? Also, what would be the best value resistor?
Thanks,
Allen..
Allen...
Old 2nd November 2010, 03:16 PM   #1872
sendler is offline sendler  United States
Default AC ?
Originally Posted by ranger3 View Post
Quick question.
Thanks,
Allen..
Don't you want to use an AC switch to turn off the power supply and the amp together?
Scott
Old 2nd November 2010, 03:24 PM   #1873
I have a 10 amp Astron PS that I have 2 amps connected to. I need to be able to control the power to each amp seperately.
Allen...
Old 2nd November 2010, 04:34 PM   #1874
Default Guess
Quick question.
Thanks,
Allen..
I would guess that ground would just go straight in and back out from the ground pin if you want the led to work. You might have to remove the original led resistor and put in a bigger value. 3 times as large? Positive goes in on the + and out on the A? Measure for continuity with a volt meter while operating the swaitch to find out how it is set up.
Scott
Old 3rd November 2010, 10:39 AM   #1875
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi there,
as a PSU is quite expensive:
will a single MeanWell 36V/9.7A down to 32V be enough for 2 amps, each driven hard as speakers are not efficient? A dedicated PSU on each amp will bring something sound wise and/or having 2 will avoid for a single one's fan to turn on?
second, going for a big heatsink and passive cooling (hope it will be reliable with 86db/W speakers...), will the PSU turned down to 30/28V (and bother with PCB's linked R) allow for less heat, enough to sacrifice SQ and time wasting in changing R13, R17, R25, and R31?
Thanks!
Matthieu
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, TDA1387, UCD400, JBL 4313B: music!
Old 3rd November 2010, 11:07 AM   #1876
Default 4 channels?
Originally Posted by Malefoda View Post
Hi there,
Thanks!
Matthieu
Do you need 4 channels? Running two amp boards from one power supply sometimes generates a weird, whistling noise. You will need two supplies. My Zalman heatsinks never get hotter than 50C at 32V.
Scott
Old 3rd November 2010, 11:12 AM   #1877
Malefoda's Avatar
Hi Scott,
yes I do need 4 channels, and here I go for 2 SMPS & the Zalman
Old 5th November 2010, 02:16 PM   #1878
What I did was, put a 680 ohm resistor in line on the ground side. Works well at 24 volts. I have to try 30 volts next to make sure the LED isn't to bright, otherwise I will need a larger resistor.
Thanks for your help.
Allen ...
Allen...
Old 8th November 2010, 07:36 AM   #1879
Baka is offline Baka  Montenegro
Default Hi DC on output
I've been doing some well known tweaks this weekend such as changing of inductors with Wurths, changing the output filter caps, removing unnecessary binding posts, input capacitors and diodes.
Unfortunately, hi DC appeared on output. Depending of the input gain it's 22V and 24V, both channels. With the gain off there is no output dc.
What could went wrong?
The supply voltage and polarity should be of no concern.
Removing binding posts and output inductors was particularly painful so even overheating comes to my mind.
Is tc2000 damaged or tp2050 or both?
How could I check this?
Thank you all guys.
Baki
Old 8th November 2010, 08:48 AM   #1880
col_s is offline col_s  Australia
Baki
You shouldn't remove the input cap on tripath amplifiers. This is because the input is biased at 2.5v. Without the input casp, the 2.5V DC will be amplified and appear as high DC on the output.
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright 1999-2017 diyAudio
