| Class D Switching Power Amplifiers and Power D/A conversion |
#1331 | |
A passive heatsink is fine, but generally a designer evaluates the correct functioning of his design by measuring the temperature and when it is too high you connect a scope to the switching waveform to see what's going on. The temperature you guys are all mentioning makes me suspect there is something going on there, like I've said a few times now... It shouldn't get so terribly hot. I can cool my TK2050 amps with a thin and tiny slab of aluminium when I run them at 24Vdc! Can someone back this up? Kristleifur? You can place the whole world of aluminium on top to keep it cool, but if the cause of the problem is elsewhere why would you? In Dutch there's an expression for this, literally translated:"Mopping with the tap open..." Then why on earth would you alter the zobel? Perhaps it gives a satisfying skewed frequency response, but the same applies here, when the problem lies elsewhere (usually in the speakers) why would you? You guys HAVE to understand the output filter has only little relationship to the audio quality itself. Sure it has an effect on the flatness of the response, but using audio grade components here is asking for other problems. Like emissions, one day you'll notice your TV starts distorting when the amplifier is turned on, or some wireless device is not working or going mad, or stuff just dies around you.... But also here I say the choice is yours.... Even though I find some parts a bit exaggerated, yet he even could have added things on top which he stayed silent about in the article (compensates the exaggeration well ) here's a very good read:http://www.audioholics.com/education...-basics-page-2
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... Last edited by v-bro; 12th April 2010 at 08:22 PM. |
#1332 |
Yes, I think it may have a malfunction.
I use a single Meanwell driving two 4X100's and the fan has yet to come on. My PS is is an oversized all metal enclosure. I am sure that helps. And the two 4X100' boards are each in their own metal enclosure. Time to check primary wiring and grounds! Last edited by alevans51; 12th April 2010 at 08:36 PM. Reason: Expansion of original response. |
#1333 | |
But this is a bargain hunters thread, thus my preaching will probably be invain... ![]() Really the idle current of this amplifier is probably enough to make the fan switch on. The offset trimmers can have a little effect, but not much. If it changes much then your speakers will have smoked out long before that. The trimmers on the sure board are single turn junk by the way, a good mod actually would be to mount some good Bourns multi turn trimmers there. At least then you can be certain that after playing loud a good rock track your offset will remain unchanged! I have repaired a Passlabs X150 a short while ago which had single turn trimmers. I had the idle current and DC offsets trimmed nicely after breaking serious sweat and after I just gently tapped on the board I could start all over again. Pulled the suckers out and cuisined some nice 15 turn trimmers in, now it is running solid! That said I am a bit afraid the Sure board doesn't allow for much larger trimmers, but Bourns have a miniature version as well.... Without proper examination of your Meanwell supply it's very hard to say why the fan is turning on and whether it is normal operation or not...A good start is to start at the load, measure the current consumption. Or an IR thermometer could perhaps provide some answers. Or maybe you can work around it by choosing a different fan. But then be sure the consumption is the same! And the air displacement! And of course the voltage!!
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... Last edited by v-bro; 12th April 2010 at 08:42 PM. |
#1334 | |
Edit: until resolved: Dont try
Found something: According to the Tripath datasheet, the config pin (pin 24) should be connected to Vcc, whereas sure connects it to the ground. With pin 24 to ground, the TK2050 acts as a stereo amp chip, whereas it is a bridged amp chip. Quote:
Edit: Until resolved: Dont try Last edited by teamacc; 12th April 2010 at 09:00 PM. |
#1335 | |
EDIT: At hind sight the Sure board IS for parallelled TP2050 configuration, the Sure documentation present something that in my view wouldn't even work. If both bridges in each chip would work in counter phase (Config pin to GND, 'stereo' operation on the chip) then a board design for parallel operation would short circuit them out completely... Config would HAVE to be tied to VDD...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... Last edited by v-bro; 12th April 2010 at 09:25 PM. |
#1336 |
There is just an error in the sheets I hope... it couldn't be like this on the Sure board!!
Pic1 From the Sure sheet Pic2 From the Tripath datasheet Pic3 Description from the Tripath datasheet
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once...... |
#1337 |
#1338 |
[QUOTE=v-bro;2151349]I can't see why Sure hasn't connected it to the main ground by default?!
it's so easy to use a comercial fan with its own wire.,this is a chinese amp,they won't add a couple of wire outside the board.this is a cheap amp,not the best design. like the capacitor for analog low pass filter A passive heatsink is fine, but generally a designer evaluates the correct functioning of his design by measuring the temperature and when it is too high you connect a scope to the switching waveform to see what's going on. The temperature you guys are all mentioning makes me suspect there is something going on there, like I've said a few times now... It shouldn't get so terribly hot. I can cool my TK2050 amps with a thin and tiny slab of aluminium when I run them at 24Vdc! Can someone back this up? Kristleifur? You can place the whole world of aluminium on top to keep it cool, but if the cause of the problem is elsewhere why would you? In Dutch there's an expression for this, literally translated:"Mopping with the tap open..." ok,before build this amp,i've try a UCD topology (with post filter feedback) i gave up this design because of bad THD,due to the layout,class D amp need SMD component. the link IR2110 failure with a scope probe Then why on earth would you alter the zobel? Perhaps it gives a satisfying skewed frequency response, but the same applies here, when the problem lies elsewhere (usually in the speakers) why would you? You guys HAVE to understand the output filter has only little relationship to the audio quality itself. Sure it has an effect on the flatness of the response, but using audio grade components here is asking for other problems. Like emissions, one day you'll notice your TV starts distorting when the amplifier is turned on, or some wireless device is not working or going mad, or stuff just dies around you.... sorry,i wrote something false,zobel is 470nF+10 Ohms. i own a digital scope meter,the SURE kit do not have a zobel on the output. you can check it easily. But also here I say the choice is yours.... Even though I find some parts a bit exaggerated, yet he even could have added things on top which he stayed silent about in the article (compensates the exaggeration well ) as i said,in this case,component size are very easy for me to exchange,the size do not deteminate the quality of the amp. i won't take the soldering station for 2 SMD components. next i will post some THD and IMD measurement.
#1339 | |
I'd like to avoid the fan version if possible. ![]()
#1340 | |
I think so it says on Sure's website "You can use any number of channels you like, and leave the others unused" |
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 11:41 AM |
