Go Back   Home > Forums > Amplifiers > Class D
Old 10th April 2010, 11:30 PM   #1311
same64 is offline same64  Australia
hi guys just one question.Should i install potenciometer.I do have passive preamp..
Whats best option?.
Old 10th April 2010, 11:45 PM   #1312
wwenze is offline wwenze  Singapore
Originally Posted by Jumpin John View Post
Yes I have one and it performs much better than the cheesy 24volt wall-wart that I had been using. The Meanwell clone eliminated the distortion in the bass drivers I was getting from the 24 volt supply and the amp sounds great running at 30 volts. Externally, the smps seems solidly built, comes with a nice stainless steel case, and AC and DC power cords. I can't attest to the quality of the innards, I'll leave that to someone more knowledgeable. The power supply gets warm but not hot, and so far the cooling fan has not been activated. Tracking of the shipment from Modders is via the Sure website, the PayPal payment went to a Sure email address, and the recipients name is the same as on the amplifier board. Add it up, and you get Sure electronics as the vendor.
Oh, so it's a Meanwell clone, my mistake before then.
Chinaaaaaaaaaaa..............
Old 11th April 2010, 02:45 AM   #1313
sendler is offline sendler  United States
Default Volume control
Whats best option?.
The shortest cables (none) following the lowest value pot that your source will still drive well (10k?). Or better yet, if the volume levels work out, straight in with small amounts (0 to -10db) of digital volume control from your media player.
Scott
Old 11th April 2010, 12:12 PM   #1314
Thanks sendler..
One more thing,,,I don't understand how that MUTE works.
Can someone explain me in simple language how to connect cables ..
Can i leave amp on ?.
I know there is somewhere written in posts but cant find it,.
thanks in advance..
Old 11th April 2010, 01:20 PM   #1315
Default Mute
Thanks sendler..
thanks in advance..
Connect 5v to mute for mute.
Scott
Old 11th April 2010, 01:40 PM   #1316
I am assuming it is a Meanwell clone because there is nothing on the case calling it a Meanwell. The case is slightly different than pictures of the Meanwell, and the weight is listed at 1056g for the clone and 1134 for the real thing. Otherwise the spec sheet is lifted directly from the Meanwell. Both product numbers are PT-IP012, and the model number is S-350-27 on both. Because of the weight, I am guessing that the insides are different.
Old 11th April 2010, 02:17 PM   #1317
v-bro is offline v-bro  Netherlands
v-bro's Avatar
If it's the same SMPS as here:forum.zelfbouwaudio.nl • Toon onderwerp - 2 * 100 watt klasse D module.
Then I can only say don't buy it. Reports are that the fan in this device is super noisy and the guy in that thread reported smoke coming from it.
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 11th April 2010, 03:20 PM   #1318
teamacc is offline teamacc  Netherlands
I'm also guessing you better pay those 10$ more and get some (better) quality.
Edit: just set the gain to low. Much less hiss now in idle. (barely/not audible when 10cm from tweeter)
Old 11th April 2010, 05:12 PM   #1319
The Google translation isn't that good but it sounds like they are discussing the contact of Meanwell to resolve the problem so I guess that is who made it("Je kunt beter Meanwell mailen"). The pictures don't look like my supply at any rate, and the fan has yet to be activated so I can't tell if it is noisy. Definitely no smoke so far and it is working well.
Old 11th April 2010, 05:25 PM   #1320
In hindsight, you are probably right if the quality is indeed better.The difference in price is now around $13.50 US, not that much if the Meanwell is a better unit.
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
Copyright ©1999-2013 diyAudio
