| Class D Switching Power Amplifiers and Power D/A conversion |
#1261 |
I dont know if any of you guys have the same problem, but when I listen to "bring me to life" by evanescence, the bass in the intro of the song seems misplaced. Its not the record, but it might be the speakers OR it might be the amp.
Running a 2.5-way B&W set. (seems like the tweeter and the woofer are out of phase, or dont mix that well together) Other songs sound great. |
#1262 | |
#1263 | |
#1264 | |
The passive woofer (.5) is causing some distortion of some kind, as it kinda laggs behind the normal woofer. The tweeter and the amp are fine
#1265 |
Thank you Dr_Vega. Putting extra tank caps under the board makes sense. Those are some big *** inductors. Did you try winding air toroids? Not that they are any smaller. I'm going with the Arjen coils for now, and have some Wurths on back order. There is someone selling 5A T-amp coils on ebay and they will match them to 1%. Choke coil for class-D T-Amp 10uH 5A - eBay (item 270558842628 end time May-05-10 06:35:43 PDT)
Regards, Free |
#1266 | |
Arjen's coils are much better than stock. The air coils are that much better than the Arjens. Scott says the Wurths are as good as the air-coils. I haven't heard them, so I can't comment except to say that I value Scott's judgement. -dr_vega |
#1267 |
Hello,
i think trying another air toroid is a mistake,the wiring out the board can not provide good results,i've try to build UCD clone,the layout was the basic error. otherwise: for the tk2050, noise is comming from the fan ,it's obvious the best and easy way is to connect the fan ground dirctely to the 0 V supply.to avoid common impedance. when the kit comes,we can easily transform the heatsink. there is another heatsink whith a fan,i've screwed it with the another (without the fans ) i'm still listening whith it,temp is about 45° with 25° ambient temp. very good amp for the price. Last edited by thierry38efd; 6th April 2010 at 08:32 PM. |
#1268 | |
There are plenty on ebay to be had, even fully made are reasonably priced. Any ideas which sound best ? tube buffer, Consumer Electronics, Tube Amplifiers, Preamplifiers items at low prices on eBay.co.uk |
#1269 | |
I think I am correct in saying that efficient speakers need lots of volts and inefficient (and normal) ones love plenty of amperage. |
#1270 | |
Scott Last edited by sendler; 6th April 2010 at 10:17 PM. |
| FS: Sure Electronics Tripath Board tc2000+tp2050 | wimdehaan | Swap Meet | 9 | 24th July 2009 11:41 AM |
| Page generated in 0.10723 seconds (68.67% PHP - 31.33% MySQL) with 11 queries |
