Sure Electronics New Tripath Board tc2000+tp2050 - Page 122 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 23rd March 2010, 10:27 AM   #1211
v-bro is offline v-bro  Netherlands
v-bro's Avatar
Originally Posted by Zero One View Post
The test board now has 80 hrs up so I won't add the coils or make other changes till 100 hrs is up which should be Thursday. Even then only one thing at a time. That will include Low ESR caps at the chips (as close as possible) optimisation for 26V (roughly what it runs at of the batteries), possible changes to the 5V line and power routing.
41hz AMP4 has the caps miles closer to the chip by default. Note that when placing the caps floating above the board the pin length will diminish the ESR performance.
Hey V Bro, I agree about the scope, I don't own one but a good friend who is a retired audio tech does and I am sure he would love to spend some time doing serious testing with me.
As always all input is greatly appreciated.
Okay, well I bet the guys here would love you to post here about your findings!
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 23rd March 2010, 10:47 AM   #1212
V-Bro Happy to report back on the tests when done.
I was thinking of mounting the caps under the board, where the chip is, I need to check the options, I will lay the caps flat and rotate the caps to get the positive terminal as close as possible, mounting right at the chips I think would be a problem due to heatsink location I think.
Thanks for the tip.
Old 23rd March 2010, 03:34 PM   #1213
wwenze is offline wwenze  Singapore
C) lastly find a way of adding extra pressure to the heat sink without causing any problems with board distortion etc
Washers - put them on the underside of the board and poke the push-pin through them
Originally Posted by soldersmoker View Post
What's the approximate pitch of this "buzzing noise" you hear? 60/120 Hz? Or higher? I don't hear any such thing and I have 96dB/1W/1m speakers. Do you have the volume cranked up high when you hear the noise?
I'd like to replace my fan on principle, just to remove a moving part that will eventually need replacing anyway. But I never hear any buzzing.
For me the MSI fan buzz is there with no source connected and lowest gain, the frequency follows the RPM of the fan and I suspect it to be the same numerical value.
Won't get to do anymore test on that now that it's gone forever. The entire heatsink which I left on my table disappeared totally, spooky.
Old 23rd March 2010, 03:49 PM   #1214
sendler is offline sendler  United States
Default Not getting it
Hi Sendler My fan is the later ones not the blue one, but it is running off a totally separate battery, so PS doesn't some into it. As far as the noise of the fan itself, it is very quiet, what is able to be heard is a sound that is quiet mechanical in nature though the speaker.
I must emphasis this is very very low level stuff, but I am totally anal retentive when is comes to getting the cleanest sound possible, other wise I would never have built a totally off the grid system (including analogue and digital front ends). I know most folk will never hear a lot of this stuff but my philosophy has been totally eliminate all noise and then optimise from that point on.
There is some low level circuit noise and that will certainly be dealt with but the fan noise is a little louder than that but it is quite possible those listening to amps fed via SMPS will not hear it as it would likely be buried beneath the increased noise of the power supply
I feel that the microphonics (if we can call it that) is indeed related to the heat sink, which is spring loaded to the chips, there is in fact very little effort required to wiggle the sink against the springs. I suspect the heat sink chatters against the top of the chip in sympathy with any external vibration and somehow this translates through the system, by means unknown. Pressing down on the heat sink kills the noise totally.
My intended solution is to A) remove the fan from the top of the heat sink and mount remotely above the chip. B) place small slivers of rubber or balsa between select fins of the heat sink and C) lastly find a way of adding extra pressure to the heat sink without causing any problems with board distortion etc. I will also ensure that all connections, coils and caps are very firmly mounted to the board.
Once this is dealt with residual circuit noise is next on the agenda, to that end all coils are in copper pipe tubes sealed at one end, and there will be double sided copper clad boards on either side of the amp board grounded to a single point. I am also looking at the best place to take the ground off the board, I doubt the current location is ideal, I know from Dacs and Phono pre amps that little things like that can have a reasonable bearing on circuit noise and overall sound.
If it all works out then I will build up 6 boards for my 100 db efficient OB system.
I am definitely not getting any microphonic or piezo electric noise from banging on the blue heatsink with my ear touching the speaker drivers. I'll try one of my third version finned/ fan amps when I get a chance to see if they are any different. Do you have another board? Maybe there is something wrong with yours.
Scott
Old 23rd March 2010, 03:54 PM   #1215
Default Passive cooling
Originally Posted by SoldierAnt76 View Post
I can confirm that the heatsink fan is audible through the speakers. When I stop the fan with my finger, the buzzing noise goes away. When I release my finger, the pitch of the buzzing rises as the fan spins back up. So the two are linked.
It isn't a big deal, but it adds to the background noise you hear when the amp isn't receiving a signal. Maybe replacing the fan with a bigger heatsink is the solution?
Your passive volume control and internal wiring is picking up the noise. The easiest and cheapest thing for us all to do is change the heatsinks to a slightly larger passive such as the $6 Zalman.
Scott
Old 23rd March 2010, 10:57 PM   #1216
teamacc is offline teamacc  Netherlands
I ran my fan off an 7805 regulator, and most of the noise went away. I think going passive is better though.
Old 24th March 2010, 12:42 AM   #1217
[QUOTE=
Won't get to do anymore test on that now that it's gone forever. The entire heatsink which I left on my table disappeared totally, spooky.[/QUOTE]
I got the same result when I first fired up my Sure a couple of weeks ago. The gain is also set on low for the recommended pre-amp setting. I tried it with the fan removed which cured the problem but the heat was getting pretty intense. My next move was to remove the existing wires as close to the fan body as possible and replace them with shielded teflon insulated and wrapped wire I found in a surplus store. While the fan was off, I used aluminum foil tape to shield any part of the thing that wasn't moving. The wires were reconnected to the 5 volt and negative terminal blocks farther from the chip than the original connection and the buzz is pretty much gone. There is a very slight hiss in the left speaker which is connected close to the fan hook-up. With my ear to the right speaker, the hiss is barely audible. With the fan running, the heatsink is very cool to the touch, no meltdown imminent! I was also getting some audible distortion in dynamic bass drum on Kodo's Mondo Head SACD (which is about as dynamic as it gets). I was using a 24 volt, 600ma wall-wart until today when I received a Meanwell clone, 27 volt 13 amp smps from Modders on eBay. In short, distortion is gone and the amp sounds great. My speakers have a double voice coil base driver and need a bit of current, so I suspect that the 600ma was the problem. The amp is driving a pair of Energy Veritas speakers(87db) and the source is a Bryston BP25 pre. It is a great sounding combo, and the Sure is at least equal in hi-frequency and mid range detail to my Bryston 3B-ST ( around 120 watts) but the Bryston will obviously play louder when required and have better control of the bass. The dynamics of the Sure are amazing for an amp of that size and I think the overall sound quality to be far superior to my modded Trends or Sonic Impacts (I have 3 of those). Thanks to all of the leg work from forum members, I am replacing some of the usual suspects on the Sure board. The input caps are Black Gate 4.7 uf N's( contrary to conventional wisdom of no electrolytics in the signal path) because I have a few kicking around, they are small, and I like the sound with Tripath amps. The tank caps are two Pany FC 2200 uF 35v, overkill probably, but again they were what I had. I have some coils coming from Argenhelder because they were mentioned here a few times and they are easy to order on fleabay, quite scientific. The case is a work in progress but I am slowly getting there though I kind of like the bare board look, with wires and caps hanging out.
Old 24th March 2010, 02:04 PM   #1218
MikeHunt79's Avatar
Originally Posted by v-bro View Post
Looks like it is running on a very high frequency, there's just 1000uF 35V inside now.
Looks like you can drill a few extra holes there in that PCB to swap it for a bunch of smaller caps...
EDIT: I see a 100uF 50V cap on the output as well....
Hi, I eventually got around to finding the switching freqency, with a little trial and error:
(apologies for the poor pic)
I measured the voltage on one of the legs of the biggest IC. I think it's either 66KHz or 132KHz, which I think is higher than the Meanwell SMPS, and it seems to sound a little nicer with this SMPS, but there is very little in it.
I'm not really familiar with SMPS's in the same way that I'm familiar with linear PSU's, but am I right in thinking adding too much capacitance would be a bad idea? Are there any calculations or formulas I can use to work out a good figure to aim for?
Right now my plans are to leave the SMPS alone, and have the Sure board with 3000uF of capacitance, so around 4000uF of capacitance in total... I guess thing should be more than enough assuming the switching frequency is 60KHz+?
Old 24th March 2010, 02:34 PM   #1219
(Anecdotal: I'm running a pair of 41Hz Amp11's at 20V without any heatsink at all. They have been running like that for at least half a year. No trouble at all. ... I can't imagine why the Sure needs a fan on the heatsink.
By which I mean: The fan is probably not needed at all. Except in a very cramped and closed enclosure.
Old 24th March 2010, 03:26 PM   #1220
Default Failures
That's weird because the 4X100 thread reports numerous failures due to the warped piggyback board not allowing a close seating of the heatsink to the outside two chips. And, Sure went to the fan after first selling the 2X100 with a small fanless heatsink and having some failures when used with voltages beyond 24v. I am hoping to run the newest version heatsink without the fan because they do pollute the critical 5v supply unless you install another dedicated supply. I have some amps in the box but haven't tried it. I will measure the temp and report back. I have been wondering if Sure's biggest problems were caused by the thick rubber adhesive they used to use to glue the heatsinks on with which they have gone away from on the newest heatsink.
Scott
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 12:41 PM
Copyright ©1999-2017 diyAudio
