Sure Electronics New Tripath Board  tc2000+tp2050
Old 13th October 2013, 08:32 PM   #2311
Malefoda is offline Malefoda  France
Malefoda's Avatar
Send a message via MSN to Malefoda
Hi there,
anyone to explain how Sure has done the Mute on their board ? Cap, 5v and R... can't figure what it does.
Anyway, Mute pin not connected mutes the amp and Mute pin to ground un-mute, right? Or +5V to Mute pin to mute?
Having a terrible thump at power off (nothing at power on, not that big 2uF input caps) I hope muting the amp prior to power off the amp can save my speakers and sanity.
QED T260, Thorens TD-318 & Ortofon Super OM 20, Teac VRDS-10, Buffalo II & NTD1, UCD400, JBL 4313B: music!
Old 17th October 2013, 01:19 PM   #2312
Malefoda's Avatar
Removed all the Sure's stuff, a switch to "floating"/grounded state, used prior to power on/off to mute it manually. Simple and smooth.
That was my DC supply switch, now my "amp ready" switch
http://www.diyaudio.com/forums/class...ml#post3664472
Old 17th October 2013, 10:08 PM   #2313
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Nice idea putting heatsinks on the inductors, I'm tempted to try that myself as mine are still getting pretty warm. Also I'm tempted to try a simple timer circuit so the amp starts off in a muted state, then unmutes after a second or so...
I'm using the old revision board however, and as for a turn off thump I do not really get much of a thump so never needed to touch the mute switch (yet)...
Old 18th October 2013, 09:14 PM   #2314
Malefoda's Avatar
In fact prior to my low noise 5V and my paper in wax caps there was no power off thump. Can't tell wich mod did this.
Anyway, cooling is OK, 60C at 15V reg and coils, 40C max at the TP2050.
Old 25th October 2013, 10:11 PM   #2315
PetrosD is offline PetrosD  Greece
Hello to all!
I read almost the whole thread because I have this board and I like it a lot.
But I tried to do something (to use the board for something other than drivin a speaker, please don't ask yet what) and I made a wrong connection and the amp doesn't work anymore.
The wrong connection was to connect a +12 volts (relative to input ground) to the + side of an OUTPUT channel.
Does anyone have the knowledge what would this do to the amplifier?
Old 26th October 2013, 12:53 AM   #2316
Virpz is offline Virpz
I am not sure about the extent of the damage you can achieve by doing such a thing but I am pretty sure it did burned out a few important things and you can buy a brand new board.
Old 27th December 2013, 07:42 PM   #2317
Apachestar is offline Apachestar
I have the new sure 2*100 aa-ab32186 and it seems to operate differently than my older board. I recall the older board turning off the fans when idle. But this one the fan runs all the time. Also, I bought the sure PS 27v for this and the fan noise sucks! It is way too loud. Any recommendation to quiet it?
Old 27th December 2013, 08:20 PM   #2318
Hi there.
You can replace these fans with other more silent for the amp and PSU. For the amp you can also provide a good passive cooling solution like a good copper fanless heatsink.
[]'s
Old 27th December 2013, 10:40 PM   #2319
Default Sure PS noise
I remounted the fan with some elastic material between it and the housing. The noise went down a lot, but still it's loud. My old sure PS (which was MeanWeil) and amp did not have the fan come on until the temp hit a certain limit. I'd like to do the again, as I have the amp near a chair and you hear the fans when no music is playing. Any ideas how to have the circuit kick in when the temp hits say 100F?
Old 27th December 2013, 10:43 PM   #2320
Virpz
Thanks for the reply. Any recommendations? Any that have a thermal circuit and do not come on until required? (Or more likely a way to to off the amp or PS). It seems crazy to run the fans 100% of the time.
Sure Electronics New Tripath Board  tc2000+tp2050Hide this!Advertise here!
FS: Sure Electronics Tripath Board tc2000+tp2050 wimdehaan Swap Meet 9 24th July 2009 11:41 AM
