I remounted the fan with some elastic material between it and the housing. The noise went down a lot, but still it's loud. My old sure PS (which was MeanWeil) and amp did not have the fan come on until the temp hit a certain limit. I'd like to do the again, as I have the amp near a chair and you hear the fans when no music is playing. Any ideas how to have the circuit kick in when the temp hits say 100F?
I know what you mean as I never seem the fan on with my MW power supplies.
You can get two of that passive heatsink or a temperature active fan like this one
The links do not work. I do not know if my old MW ever come on. I might try running this without any fan, and see if the temp overload kicks in. The PS sits in a well ventilated space with the sure amp pushing minimal air via its fan. Then, if its cutting out I could add a temp active fan (ill google those and find one, I'm sure. ). Thanks for the help.
Ok, I am going to ressurect this thread....
What I have done with this board ( Ver. AB32186V220 ) :
Awesome, but I have some questions.
1- Replaced all electrolytic capacitors with panasonic FM and FC.
OK. Makes sense.
2- Replaced inputs caps with 2.2uF mundorf ( keep legs short ) .
Yes, still with you.
3- Added 550uF electrolytic to the tc2000 .
OK, I'm lost. Can you please state specifically what you did, and/or show a pic?
4- Added a separated board for the output filter;
- Low pass Rifa PHE 426 ( I love these caps ) .47uF and baked air cored Litz inductors of 10uH ( Will replace inductors with wurth 7447709100 ) .
- High pass Rifa 0.56uF and MOX 4.7 Ohms 4W .
Perhaps this would be best for me to do later
5- These new boards even have the pads for the snubber caps and resistors, Go for 300/330pF and for the resistor go for 20 Ohms 1/4W
Again, if you could provide precise instructions and/or pics, please?
6- Inverted the fan for better air flow.
7- provided a case, alps pot and all the wiring was done in Litz because I had these around and someone said that I could avoid proximity effects by using it.
Nice job!
hello.
I have a muse dt-50 2x50W amplifier that uses the chip TC2000 + TP2050, and one of the two channels fail, only sounds clicking the other works with normally. Would they tell me why this happen? the board is this:
60RFNDXzk3NzI http://museaudio.com/photo/album/usaFeBhNZm_% @. jpg
the board has a pin ISP +5 v GND RXD TXD, someone has to configuration parameters?
Thank you very much!
hello.
I meant to say one of the two "speaker" channels.
Hi there,
Unfortunately the version I am planning to get for tweaking seams different from these discussed here. Will you please comment that one - TK2050 50W 50W Class T HiFi Stereo Audio Digital Amplifier Board DC 12V Voltage | eBay
Thanks in advance,
Ignat
Thanks in advance,
Ignat
Getting high pitch tone!
I have a Sure model AA-AB32186 board, and while desoldering the input caps,
I accidentally knocked out R1 and R2 (22k). I intended to replace input SMT electrolytics with regular film caps.
These R1 /R2 resistors go from input to ground and appear to set the input impedance of the amp.
Measuring across each RCA jack then, I got about 75k ohms on my ohmmeter.
I hooked up a speaker to the outputs (no input) and the green light came on (good), but when I put a 22k ohm(1/8 watt) resistor across the input to ground (with or without input connected) I get a high pitch tone (oscillation?), and the green light doesn't come on.
I need a schematic for the input circuit of the AA-AB32186, to determine if the 22k shunt resistors go before or after the input caps (can't tell from the pcb traces).
Thanks in advance!
-Chas
Thanks in advance!
-Chas
Input impedance for coupling cap calculation?
As mentioned above, on my Sure model AA-AB32186 board, I noticed that the input coupling cap is in series with the input after the 22k shunt resistor[first image]. The resistance from shown test point to ground is 76k ohms.
BTW, I've replaced the damaged 22k shunt resistor with an 18k 1/8w 1%metal film resistor, since it was the nearest value small resistor I had on hand).
In most input circuits the shunt resistor is after the series cap, making input filter frequency calculation easy[second image].
How does one determine the low frequency cutoff in the first case(i.e. using the 76k or the 22k as the input impedance)?
TIA
TIA
Sure STA508 - midrange issue
Hello!
I'm new to this forum and don't know if I should post here or start a new thread about this. I have built an amplifier consisting of a Sure STA508 amplifier board and a Delta 24V/150W switch mode power supply. I'm very happy with the result, except a strange issue in the midrange. A very narrow frequency in the midrange, I guess somewhere around 1k, is boosted and sometimes sounds distorted. It's not very audible unless a tone hit that specific frequency, typically vocals, electric guitar etc. Have any of you experienced this issue and have an idea how to solve this?
Thanks for any help!
I have studied the frequency response and pulse response using a dummy load (pure resistive), signal generator and oscilloscope but have not noticed any issues (except the modulation frequency present at the output).
Hello!
Hello osflaa,
I have not noticed this issue at all. I use the same Sure board, powered by an Omron 24v SMPS. The only modification I have made is to remove the input capacitors and replace with Russian K73-16 caps (however I did not notice any issues with the stock caps in place, either).
Hello osflaa,
Thanks for your reply!
I try to eliminate other potential sources to the problem and it can be something wrong with my TV-decoder/DA-converter because I have noticed the issue when watching TV. But I find it very strange that this should occur at the same time as when I started using the amp. Anyway, I have connected a CD-player (yes, I still use it ) directly to the amp now and will listen to several albums.
Solved
The distortion disappeared after rebooting the DAC, so it must have been some kind of sync-issues. Weird The amp has a relatively dominating midrange, but was not the source of the distortion.
(BTW: I should edited my previous post instead of writing a new, but it seems that this feature is removed while my forum activity is under censorship )
...it can be something wrong with my.. DAC...
- Class D
- Sure Electronics New Tripath Board tc2000+tp2050
