Go Back   Home > Forums > Amplifiers > Class D
Old 29th April 2009, 12:59 PM   #1
darkfenriz's Avatar
Default Ripple steering?
Hi all
Please have a look:
http://www.extron.com/download/files..._d_ampl_wp.pdf
Interesting read on how to make class D without any output ripple, however I've got a gut feeling something's wrong in it. Cannot figure out what for now, maybe I am wrong and missing something elementary...
Need your opinions!
Old 29th April 2009, 06:09 PM   #2
diyAudio Moderator Emeritus
Hi, Darkfenriz,
You can look at US patent #7167048. But it won't work for UCD style, the ripple is needed for UCD amp to work.
Old 30th April 2009, 07:01 AM   #3
darkfenriz's Avatar
Yes, that's the patent.
The whole idea is new to me. What's the nature of filtering?
Brickwall filters don't exist and if they do to some extent, they are not for free.
Do you know the crossover frequency between main and auxiliary output and probably the current ripple through the auxiliary output?
BTW, scope shots donn't look very nice at the paper...
Old 30th April 2009, 10:04 AM   #4
I am not sure whether zero current ripple in the output inductor is desirable at all. And how "zero" voltage ripple in the load can be achieved is old hats IMO.
Charles
Old 30th April 2009, 05:20 PM   #5
I'm also not very clear about the inverted current direction in output filter. It makes larger current. It seems they wanted to get rid of mosfet's body diode reverse Qrr spikes, but in compliated way. Why don't choose a better mosfet instead?
Maybe EVA could give insight about this?
Old 4th May 2009, 01:55 PM   #6
darkfenriz's Avatar
Well, I believe it is more about being a steep crossover passing audio current into load and everything above to a secondary circuit. No circuit can have such jump in impedance from nearly nothing at 20kHz to very high at 130kHz (switching freq,) and above (harmonics).
So probably there is still some ripple current, just passing into the other coil.
Please correct me if I am wrong.
Old 5th May 2009, 05:21 AM   #7
MOER is offline MOER  United States
We have tried this in the class D amplifiers using both pre and post coil feedback. It does nothing.
However in switching power supplies especially power factor correctors it sure does help
Stephen Mantz
Zed Audio Corporation
Old 5th May 2009, 02:28 PM   #8
It could help that the amp's output signal looks more like that of a conventional linear amp - which can be a sales argument.
This could however be achieved with other filter topologies as well - which don't necessarily remove the ripple (which assists switching at low amplitudes) from the main filter coil.
Charles
Old 6th May 2009, 02:07 AM   #9
JohnG is offline JohnG  United States
Nothing really new here. There is a Bloom and Severns article in the proceedings of the IEEE Power Electronics Specialists Conference (mid-80's, don't have it with me) covering the details.
There is no magic here. A complete analysis will show that you can add two extra poles to the file. In practical, there will always be a couple of parasitic zeros, not all of which are bad in practice; sometimes a little damping is a good thing.
Note that the benefit may be found in that the extra inductor need only carry the ripple and no DC, which can reduce size in some cases over a more conventional series inductor.
John
Old 11th May 2009, 06:14 AM   #10
darkfenriz's Avatar
Thanks for opinions.
Does anyone have any experience with series resonant LC tank instead of just C for the output filter?
Is that worth to have several LC tanks for e.g. 1st, 2nd and 3rd harmonic?
Stock HU with steering audio controls needs upgrade colo Car Audio 1 25th April 2009 10:34 PM
too much ripple steevo Solid State 11 5th July 2007 07:27 PM
steering volume control? Bad silver Car Audio 3 26th June 2007 03:47 PM
Steering stalk adapter. leekirlew Car Audio 0 20th April 2006 05:54 PM
How much ripple?? JDeV Tubes / Valves 23 2nd April 2003 11:05 PM
Page generated in 0.09522 seconds (78.26% PHP - 21.74% MySQL) with 10 queries
