diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   power supply for 41hz amp6 basic (http://www.diyaudio.com/forums/class-d/143063-power-supply-41hz-amp6-basic.html)
bull041161 27th April 2009 08:30 PM
Hi all i have just built my first amp it is an amp6 basic from 41hz and i have found a power suply at a bargain price but it is not regulated and would like to know if i can use it still the output is 12v dc 4 amps
BionicSniper 27th April 2009 08:54 PM
41hz say "External 12V typical, 14.5VDC MAX
Connector 2.5/5 mm" so probably. You just need a 2.5mm barrel connector
454Casull 27th April 2009 08:57 PM
Unregulated 12 V supplies can hit upwards of 16 V unloaded.
bull041161 27th April 2009 09:44 PM
thanks for reply so a bit risky using a unregulated supply then
Copyright 1999-2017 diyAudio
