| Class D Switching Power Amplifiers and Power D/A conversion |
HI:
This is my first post to the forum. I am repairing this amp which is using the Tripath TA0104 preamp chip. The output transistors are STW38NB20's (W38NB20) . I have found a supplier with the transistors in stock. At least one is shorted from what looks like a liquid spill near the heatsink where they mount onto. When powered up, and input signal applied, I can see the LED-VU levels bounce on both the input and output monitoring. There is a green LED near the tripath chip which is not lit, labeled 'run'. Does this mean the Tripath chip is not running and ought to be replaced? I have read about some replacements for this chip which are inconclusive. Ought I just replace it, or is the run light a sign its bad? Nothing else seems burnt, but there are 2 black color hi-watt resistors that dont seem to have any resistance at all, and may be open, but I need to remove them from the board to be sure. They are shown in the photo below each channels power transistors. Thanks. |
| Laney HCM160B's transistor | zvir | Solid State | 2 | 16th February 2009 10:23 PM |
| Laney PA amp help! | DoomPixie | Tubes / Valves | 15 | 28th November 2005 08:18 PM |
| laney PA amp questions | DoomPixie | Tubes / Valves | 3 | 8th September 2005 04:57 PM |
| laney VC50 | tuneman | Instruments and Amps | 0 | 19th July 2004 10:49 AM |
| need schematic for laney amp pedalboard | jimminy | Instruments and Amps | 11 | 27th August 2003 11:12 PM |
