| Class D Switching Power Amplifiers and Power D/A conversion |
Talk about a tight fit...
CD jewel case is for scale. Should I join the input 0V/output common together at the PSU? I don't suppose it's a good idea to let the ground current flow through the RCA jacks... |
#2 |
You should only couple grounds at high frequencies to handle common-mode EMI (major source is parasitic capacitances in the transformer). 1nF to 10nF should be enough. Coupling them to the heatsink in the same way is recommended too (to control EMI produced by capacitance between transistors and heatsink). Adding a high value resistor like 10K to 100K between grounds is a good idea too, to keep them at the same DC potential when RCAs are not connected.
I use to feel like the small child in The Emperor's New Clothes tale
#3 |
Hi Eva,
Thanks for the input. Won't the RCAs be connected to chassis ground via the headunit, bypassing whatever capacitance is used to couple them? Or is this OK because the amplifier ground is separated from the vehicle ground otherwise? |
#4 |
Consider wiring inductance (and it's antenna effect...)
Did you design the SMPS?
#5 |
Nope, the SMPS is from another thread here by "Audisoul", but the schematic is similar to the one at Elliott Sound Products... a simple unregulated SG3525 circuit.
#6 |
Hi simingx,
Which amp do you used? put schematics here |
#7 |
| Gamut D200 clone !!! | ANALOG GUY | Solid State | 69 | 16th August 2012 04:19 AM |
| Soundstream D200 | Sillyboy | Car Audio | 85 | 30th August 2009 01:22 AM |
| Impulse D200 | dede | Class D | 5 | 4th November 2008 05:33 AM |
| Soundstream D200, one channel very low | Here-I-Come | Car Audio | 4 | 21st August 2008 05:07 AM |
| Fs: Gamut D200 Mkiii | ANALOG GUY | Swap Meet | 1 | 18th June 2007 04:33 AM |
