Go Back   Home > Forums > Amplifiers > Class D
Old 13th April 2009, 03:46 PM   #1
Electrone's Avatar
Default N-Champ, discreet component class D
I have pretty much finished this amplifier that seems to satisfy my desire for a decently clean and simple class D design that I might be able to get motivated to build, given the chance.
I started with the idea of taking two N-ch MOSFETs and trying to design the simplest yet low distortion discreet circuit that I could come up with.
The output stage seems pretty well optimized, but I lack desire now to continue further optimizing the rest of the circuit. I would most likely tinker with a p2p version and if it could work much at all that way, I would be pretty confident about it.
The circuit values might be pretty close to optimum in the current mirror and the input and feedback circuits. You'd probably want to select the phase lead components as aggressively as possible in such a way to cause high frequency roll-off a little above the upper audio frequency limit. That would provide maximum load damping.
I show it for +/-40v operation. With some modifications, it ought to work on as much as +/- 100v with at least some performance loss. That's all for now. I will try to answer questions if I can.
I have left in some test options in the input and feedback circuit. I find that inverting input mode is cleaner while noninverting mode gives better DC offset.
General Thought: Why class D?
I think that since amplifiers want to try to become unstable and oscillate, why not just go with the flow and just promote it?
Old 14th April 2009, 11:30 AM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
Looks good, so will you build it? should be pretty small and +/-40v is enough for some small power setup
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 14th April 2009, 12:47 PM   #3
Electrone's Avatar
Originally posted by luka
Hi
Thanks. I might be able to build it after I build and test out my circuit for driving 60Hz toroidal transformers for another project.
On the "N-Champ" project, I am weighing the option of bridging this circuit to negate power supply pumping. I might be able to bridge it without duplicating many parts. A bridge would also permit using lower voltage. Lower voltage MOSFETs can have pretty good specifications and a lower voltage circuit is easier to work with.
Not bridging means fewer components, but bigger filter capacitors to absorb pumping. The power supply can be rated for less peak power output and be smaller.
Old 14th April 2009, 06:11 PM   #4
luka's Avatar
yep, bridging option would really be great for reasons you stated...hope to see more from this projet, will keep my eyes on it
I FEEL SLOVENIA
Old 14th April 2009, 07:02 PM   #5
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Hi Eectrone
Have you made a prototype and tested the circuit?
In my 2x150W car amp I use just 2x 4700uF supply capacitance yet pumping is not a problem. You have to evaluate it. Also, you have to try the output stage and everything to ensure that it works. Class D simulation is only reliable for control loop analysis.
BTW: I recommend differential input and feedback. You will find that the single ended arrangement picks up EMI resulting in circuit disturbance, particularly when the output is near the rails and pulses become narrow...
I use to feel like the small child in The Emperor's New Clothes tale
Old 15th April 2009, 11:14 AM   #6
Electrone's Avatar
Originally posted by Eva
Hi Eectrone
Hi Eva,
I did something not completely different a long time ago and thought that I might have an opportunity to reenter the process of tinkering with real parts again in the future.
Your thoughts are very good. I am traumatized by a long-ago filter capacitor explosion which spewed some very nasty stuff everywhere.
You give me impetus to consider the bridge with differential input and feedback. I was just considering how to implement that topology yesterday.
Those sticking PN junctions at narrow pulse widths do their mischief!
Old 15th April 2009, 12:07 PM   #7
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Electrone why did you always draw a simple schematic in its ovelry complex form using so much neonic colors with cramped spacing
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 15th April 2009, 01:30 PM   #8
Electrone's Avatar
Hi Workhorse, It's for my way of concentration of thought and my weak eyes!
Fender Champ 5C1 help needed! Spasticteapot Instruments and Amps 12 27th July 2010 11:45 PM
Floating supply in battery powered discreet preamp aletheian Solid State 3 28th March 2007 04:42 PM
269EX in a champ? ThSpeakerDude88 Tubes / Valves 6 18th October 2006 01:19 AM
JLH Class-A, component help dominic Solid State 5 29th September 2004 04:10 PM
Small discreet audio proc Draal Parts 0 2nd April 2004 06:29 AM
Page generated in 0.11109 seconds (77.16% PHP - 22.84% MySQL) with 11 queries
