Go Back   Home > Forums > Amplifiers > Class D
Old 11th April 2009, 08:38 PM   #1
Question output LPF
Hello.
I am designing a class d amp. but I need some help with the output filter, how do I Calculate L and C
I have built a small 25W amplifier that works very well with the TPA3123D2
so now I would like to build one from the start
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Page generated in 0.06556 seconds (63.70% PHP - 36.30% MySQL) with 10 queries
