Go Back   Home > Forums > Amplifiers > Class D
Old 10th April 2009, 05:40 PM   #1
mix is offline mix  Romania
Talking how many MOSFET can I connect to IRS20124
hi. I decided to build an auto amplifier.From datasheet result max load on LO and HO is 1A. I want to use 6 x IRFB4227PBF (3/rail). Somebody can tell me if IRS20124 can drive this transistors.
sorry for my bad english.
Cand beau mi-e sete...
Old 10th April 2009, 06:39 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
At which frequency?
At 300Khz certainly not without buffers...
I use to feel like the small child in The Emperor's New Clothes tale
Old 10th April 2009, 07:10 PM   #3
at 250 Khz what buffer can I use?and how
Old 11th April 2009, 09:50 AM   #4
I'm not sure that this kind of buffer it work. I need a separated power suply for the buffer transistors. Now correct my mistakes
Old 13th April 2009, 07:45 PM   #5
Eva's Avatar
Yes, this buffer style works. Zetex produces suitable bipolar transistors.
Using one buffer for each IRFB4227 will allow high switching frequencies.
Why do you think that you need IRFB4227 triplets instead of pairs or singles?
Old 14th April 2009, 09:03 PM   #6
well.. I want to use it into 1ohm load and I'm not sure that the 20124 can support the current necesary for the mosfets
Old 15th April 2009, 02:56 AM   #7
Eva's Avatar
Have you designed more class D amplifiers? Yours is a quite ambitious project.
Old 17th April 2009, 10:17 AM   #8
Bender.ru's Avatar
Hi, mix!
it was mine 1st d class project, it would be better to replace 20124 for something new, shematic also far from state of art .
How connect the Gnd. samsagaz Chip Amps 50 19th May 2008 05:09 AM
Connect TV to Aux?? yamfox Parts 6 27th November 2007 01:54 AM
Connect PWM to IR2112 to MOSFET Loobie Power Supplies 2 7th March 2007 12:53 PM
best way to connect this amp.. jonz Solid State 2 18th May 2004 06:54 AM
Page generated in 0.08625 seconds (85.32% PHP - 14.68% MySQL) with 11 queries
