multi channel t amp
multi channel t amp
Old 4th April 2009, 12:56 AM   #1
kendt is offline kendt  Canada
Default multi channel t amp
I am thinking of building one of the audio digit multi channel t amps.
I have just finished a pair of open baffle's with mtm on the top and a bass driver. I was thinking of using two four-channel boards so that I could run a separate channel to each driver.
Would there be any advantage to this kind of set up over a regular 2 channel setup. Would it be worth the extra expense?
Old 4th April 2009, 05:45 AM   #2
dweekie is offline dweekie  United States
Instead of the Audiodigit, I would suggest the new Gabrielle I started a thread on recently (diyparadise.com), or if you want to build up a board yourself, an Amp9/Amp9b (41hz.com). I thought the Amp9b was particularly nice.
Old 4th April 2009, 11:12 AM   #3
Thanks I will take a look at the gabriel. I don't mind doing the chassis work and wiring but don't think i'll get into building the whole board.
multi channel t ampHide this!Advertise here!
Creating 5.1 Multi Channel sound from 2 channel jenkrich Everything Else 5 1st September 2009 07:29 AM
multi channel amplifier Garnett Chip Amps 1 5th April 2006 10:18 AM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
multi-channel AMP? JAZZ2250 Solid State 1 15th September 2002 09:10 AM
Copyright ©1999-2017 diyAudio
