| Class D Switching Power Amplifiers and Power D/A conversion |
when i used 20V on the mosfet,and 12V on the IC HIP4080a,the ic was burned,i used the signal generater for the input of the IC,
i didn't know that why?
#2 |
anybody help me,please!!!
#3 |
Dear Freebird888,
I do not have much time to answer you. But, I saw that in your circuit the C7+R10, I would suggest that you to short circuit the C7. Also check the mosfets they must be burned and causing to your IC to burn. Also if you are using a signal generator for triangle make sure that the siganl level is in the input range of comp input of 4080. regards |
#4 |
Thinks Whortless
In fact i short the C7 ,and I am sure the input signal is correct, i found the wave of the gate of the mosfet.used the oscillograph,and i found the wave was very random,then i think the pin of the mosfet is too long,so i cut the pin more shorter,but the wave was also very random,i didn't know that why? |
#5 |
the wave of the gate:
#6 |
Freebird,
you showed only one of the gate and there are 3 left! But, according to my experience there is a problem in your PCB layout. I suggest you to center the 4080IC on mosfet arrays. It should be on the center of all 4 mosfets. So you can achive best and equal distance. I also suggest you to use slowly enable the IC by using simple C+R solution as in my shematic. I am sure that you can not correctly drive the comp of 4080 ic. Also make a blank test only with the audio signals and measure the comp out of IC without enabling the mosfet driver( use disable pin). And please upload some photos to make your thread attractive and to let someone to help you. regards |
#7 |
Thank you very much,I will layout the pcb again
#8 |
I had solved it,Power supply decoupling is very important,a excellent pcb layout and a good capacitance choosed for Power supply decoupling can reduced the peak of the mosfet'gata,and if the peak is above 95V,the IC or hip4080a will be damaged by the peak voltage.
Thanks! |
#9 |
Will you post the working version of your circut? |
#10 |
yes,I will post the working version,please wait some days
thinks |
| HELP Aleph 5 is burned? | zigo3 | Pass Labs | 5 | 20th February 2008 12:00 PM |
| Burned T-amp fixable? | jaste | Class D | 1 | 8th November 2007 08:38 PM |
| Burned capacitor | slowpogo | Parts | 4 | 6th April 2007 04:29 AM |
| HIP4080A pspice model | Anthony C Smith | Class D | 1 | 3rd January 2006 07:52 PM |
| UcD400 vs HIP4080a Thoughts? | Mike2 | Class D | 4 | 17th March 2005 02:27 AM |
| Page generated in 0.09697 seconds (75.43% PHP - 24.57% MySQL) with 11 queries |
