| Class D Switching Power Amplifiers and Power D/A conversion |
#21 |
Any switching circuit employing any trick to allow the current from an inductor to charge parasitic capacitances, thus preventing them from being charged by the switching devices with the associated losses, could be considered resonant.
I use to feel like the small child in The Emperor's New Clothes tale
#22 | |
Yes, I would need to see this also, as I dont really need 2kw @ 1khz. Could you also measure power output/consumption in 2.66 ohms stereo @ 45hz. That would be a realistic environment for me.
#23 | |
Using inductor current (small inductor eg. printed) to charge and discharge parasitic capacitance on each edge is normally termed quasi-resonant or resonant-transition because there's no cycle-to-cycle energy storage -- also referred to as ZVS/ZCS depending on how the switching loss is reduced. Most of the amps quoted by workhorse seem to be quasi-resonant ZCS/ZVS by this definition, with the possible exception of the Crown (and PKN). But as Eva said, all of them can be said to be resonant in one sense, and different people have different definitions. (yes I understand about all the different types of SMPS, we probably don't want to go there on this forum :-) If you want the highest possible power density and output power then a resonant supply has the edge if you run it at a high enough frequency (MHz?); this isn't usually the case in class-D SMPS, so I'm curious about what PKN do and why. Of course Peter doesn't have to tell us, but I suspect giving some information away is fairly safe given the increased difficulty of making a reliable resonant supply -- it's not something that can be copied easily except by someone who really knows what they're doing, and if they know this much they could design their own... Ian |
#24 | |
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#25 | |
Ian |
#26 |
Iand, did you ever investigate these amps any more?
#27 | |
http://www.speakerplans.com/forum/a-...766_page6.html but nothing further since March -- though we did find out that the PKN uses an LLC resonant SMPS, not a quasi-resonant one. Personally I'm now waiting to try out a Peavey IPR 6000, due here in a couple of months -- don't know what they'll cost in the UK but street price in the USA is said to be around $600 for 2x2000/4 or 2x3000/2... |
#28 |
Thanks for that, guess I'll have to wait for some reviews on those too
#29 | |
If they deliver what they promise then these could blow a big hole in the high-price high-power class-D amplifier market -- because I know what these really cost to build (especially in China), and this bears no resemblance to the current market prices. Prices are high now because people are willing to pay them -- and of course companies have to recoup the R&D cost needed to develop the amps, which is obviously way higher than a linear amplifier. So all high-power class-D amplifiers are expensive, nobody in the market right now wants to drop the prices and see their revenues plummet. Peavey are effectively breaking this cartel by entering the market with pricing much closer to production cost (with a decent margin, of course) in the hope that they'll sell far more amplifiers on the back of this -- the volumes in the sub-$1000 market are much higher than in the $2000+ market which is where most similar amps are right now. $600 "street price" -- which probably means lower from the cheapest suppliers -- for a 2x2000/4 2x3000/2 amp with inbuilt crossovers is *really* going to put the cat among the pigeons unless it's total rubbish -- OK maybe it won't sustain this power into 2 ohms, so use it into 4 ohms and still get 4kW for very little money... |
#30 |
Still waiting on the Peavey IPRs....
Meanwhile - I noticed PKN now offer an even larger amp - XD-6000, 2x3650W@4ohm
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
