| Class D Switching Power Amplifiers and Power D/A conversion |
Hello
Here is a very very simple class D PA amp. For sure this amp would have a high distortion. This is my first class D amp, but it is only for 100 to 300 w for PA only. Is there any errors in this schematic, and is there any suggestions of simples modifications to made it a bit better ? For Q3 I would use MJ2955 or for higher power MJ15004 How about a power mosfet for Q3 ? Thank you Bye Gaetan
#2 |
#3 |
None of them have any practical value. These are only veeeery old, very amateur experiments. Forget them!
#4 |
Right! Specialy with all transistor C-E error in second schematics!
#5 |
http://static1.album.ee/files/77/381...77381_j4rB.jpg
Simple, cheap and working not very bad, considering the quality of TL494 "built in" comparators. Try DBL494, its a little bit better one(datasheet). |
#6 | |
Hello Is there a web page giving more infos about that circuit ? Why 60 v for the mosfet and 30 v for the speaker ? Thank Bye Gaetan |
#7 | |
Unfortunately it contains some errors. U1 Pin 15 and 16 swapped, left side of R3 should be connected to U1 Pin14. Output DC level should be adjusted very precisely, carefully, without load. |
#8 |
There are much better ways to do a class D amplifier without much more parts or expending much more money.
Also, this output stage with bipolar transistors is not likely to produce much more than +/-1A reliably and is not efficient due to the voltage drop on the 1K resistors, it's designed the wrong way. Do some research...
I use to feel like the small child in The Emperor's New Clothes tale
#9 | |
).The +30V is actually PSU-s ground(not the amplifiers). Measuring the circuit is a lot easier this way. Some pics: http://static1.album.ee/album/262631/50086439 Btw this version is the first one(perfoboard), just for practice, and uses ferrite in its output filter. First three os-pictures show heavy ringing, which was eliminated by ceramic caps in power rails(C10, C11, etc; other 3 os-pics).The second version uses double sided PCB and ferrite is changed to iron-powder one(T106-2).Cam is broken and I cant make more pics... |
| simple class D amp | latala | Class D | 22 | 28th November 2012 10:24 PM |
| SImple class D amp | croccodillo | Class D | 0 | 29th May 2008 01:56 PM |
| Simple class B or AB amp. | Mr Evil | Solid State | 3 | 21st August 2004 12:58 AM |
