| Class D Switching Power Amplifiers and Power D/A conversion |
I'm currently using one to power my Trends TA-10.1, but could use some more juice - is it possible? And if, is there any point in upping the voltage to say 14 or 15V? I've mounted a heatsink on the chip, so it should be fine.
It seems to have a voltage regulator..thingie. Cheers, Johan |
#2 |
Update: could turn (literally) the voltage up to 13.68V, works fine, but are there any potential downsides to this?
Cheers |
#3 |
Only that you may need slightly better heatsinking of the Tripath chip. If it's already heatsunk, you should be good. Just have an extra look at the maximum voltage specs just to be sure.
At least that's from the amp side. Don't know how the SMPS likes the extra power, but it shouldn't be TOO bad since it's not operating at full peak power all the time. |
| Skynet 8080 SMPS | jonclancy | Class D | 5 | 5th May 2007 08:15 AM |
| 32V 8A SMPS? Skynet 8080 max voltage? | kristleifur | Class D | 2 | 2nd April 2007 12:32 PM |
| Skynet 8080 5v as tube heater? | johnthedoctor | Class D | 0 | 10th February 2007 11:26 PM |
| buzzing sound with Skynet 8080 SMPS | PIERRICK | Class D | 0 | 24th June 2006 05:32 PM |
| How do I box a Skynet 8080 SMPS | mod_sonic | Class D | 9 | 28th November 2005 11:57 PM |
| Page generated in 0.07537 seconds (72.14% PHP - 27.86% MySQL) with 10 queries |
