Go Back   Home > Forums > Amplifiers > Class D
Old 23rd February 2009, 01:52 PM   #1
Default how to connect t-amp to a single speaker
I've read that the tripath chips are already bridged, and therefore cannot be bridged further. My question is, does that mean there's no way to connect a t-amp to a single speaker?
What I'd like to try is to try my TA2020 amp on a friend's speaker. The speaker had been in a system driven by a mono 2A3 tube amp that her ex-husband built himself (thus it was a mono, not stereo, system). The 2A3 amp had died for quite a while, but the speaker might still work. That's what I'd like to find out.
So, would it be OK if I just connect the speaker to both channels on the amp? I don't want to just hook up one channel to the amp, with or without dummy load on the other (because that's not a solution- it just leaves out one channel).
TIA for any advise!
Andy
Old 23rd February 2009, 03:28 PM   #2
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default I'm no expert but.......
No, can't be done with one speaker.
They are bridged outputs.
use a dummy load on one channel for testing
and get the tube amp repaired.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 23rd February 2009, 03:43 PM   #3
Unfortunately resuscitating the 2A3 amp isn't an option: We took it to a shop, and were told that just replacing the dried out caps and blown tubes would be near $1k, and there may be other hidden problems.
If I'm not mistaken, "bridging" is to combine the power of the two output into one speaker. That's not what I'm looking to do. I just want both channels to go to the single speaker. What would happen if I just connect the + to both channels on the amp, and likewise for -? AFAIK this is not "bridging"...
Old 23rd February 2009, 04:03 PM   #4
poynton's Avatar
Look at the data sheet.
you will see why you cannot connect + to + and - to -
http://pdf1.alldatasheet.com/datashe...A2020-020.html
Andy
Old 23rd February 2009, 04:06 PM   #5
poynton's Avatar
$1000+ to replace a tube and some caps !!!!!!!
you should start a thread on here.
Someone will help you repair it for a lot less.
Andy
Old 23rd February 2009, 04:22 PM   #6
Saturnus's Avatar
fishline , you can parallel the outputs if you like, nothing wrong with that except you might experience slightly higher dc offset but in most cases it won't be a problem.
poynton, I think you misunderstood his question. The question was if he could parallel the outputs of a TAA2020 based amplifier. And there's no problem with that. However you can't serial connect (or bridge) as they are already bridge tie loaded.
Old 23rd February 2009, 05:51 PM   #7
The following link discusses and shows an example of TA2024 parallel implementation:
http://www.AudioAsylum.com/scripts/t.pl?f=amp&m=74795
Robert_S
Old 24th February 2009, 01:00 PM   #8
Thanks very much for the info! I'll give that a try.
Re: that 2A3 amp. If my friend is willing to let me try, I'll start a thread in the tube amp forum. I'm a bit hessitant because it has sentimental value for her, and I'm a complete newbie at such things.
DSP and the Single-Driver Speaker Bob Brines Full Range 178 15th October 2011 06:53 AM
Speaker connect: Speakon or banana Serge66 Tubes / Valves 12 14th January 2008 08:29 PM
Using SI T-amp with a single speaker? soupdragon Class D 5 9th July 2007 11:38 AM
Philips MFB speaker - how to connect? Martin Dellstig Multi-Way 5 22nd May 2007 12:03 PM
WTB: Belden 89259 Cross Connect Speaker Cables (ala Jon Risch) mrdon Swap Meet 1 5th February 2007 10:48 PM
Page generated in 0.09939 seconds (76.62% PHP - 23.38% MySQL) with 10 queries
