Best Layout Practices
Old 23rd February 2009, 04:02 AM   #1
gearheadgene is offline gearheadgene  United States
gearheadgene's Avatar
Default Best Layout Practices
I'm at a cross-road and could use some practical advise. What are the best layout practice on the output section, namely the 2 mosfet's and the inductor? I'm using TO-220 package on the mosfet and a torroid on the inductor. If the TO-220's lay down, the surface area consumed goes up. But, at the same time, the PCB may be a useful heat conduit keeping the 2 devices thermally equal. If additional heat-sink is required, then it could be added above the devices. If I stand the TO-220's up, board space goes down, then some type of heat sink is going to be required to just keep the 2 at the same temp.
The torroid can mount either horizontal or vertical. horizontal mount seems better for emissions, but worse for board space.
I think my board is going to be constrained for space, so maybe the only option is all vertical mounting. I'm just not how much worse either method is. Routing looks just slightly better with the all vertical mount, but no enough to sway me one way or the other. So, anyone have a decent idea here?
gene
Best Layout PracticesHide this!Advertise here!
Best AC Heater Practices Valverine Tubes / Valves 30 17th June 2015 08:23 AM
Best practices for board layout??? gmikol Parts 6 10th February 2006 05:56 PM
Sound Practices CDs Joe Roberts Tubes / Valves 0 10th February 2006 05:11 PM
Safe Practices bzdang Chip Amps 2 10th July 2004 07:11 PM
Sound Practices MAg's gilid Everything Else 0 17th January 2003 12:10 AM
Copyright ©1999-2017 diyAudio
