| Class D Switching Power Amplifiers and Power D/A conversion |
I got a 220V Capacitor (330UF).
Car amplifier connected to a Computer Powersupply 12V 60A Rail. And Basically I want to hook a capacitor to kill most of the voltage drops and ease the load on the PSU. However Im not sure how its done. Ive put in a picture.. do i do as wired in diagram 1 or 2? Thanks!
#2 |
Parallel ... with the as close to the amp as possible.
#3 |
Diag 1.....with shortest length wires.
regards Max |
#4 |
Although a 330uF, 200V capacitor won't do anything at all!
You'll need at least a 22,000uF @ 25V capacitor to have any useful effect. |
#5 |
Oh thanks people, Im not exactly sure on the UF I'll check it later on.
#6 |
I'd rather say 500,000 uF (at least) if you want significant effect! (If anything is needed.)
#7 |
½F is way too much. A computer PSU will never handle the inrush current.
10,000 uF to 22,000 uF is more than adequate for this purpose. |
#8 |
Does the 12 rail of a computer power supply really put 60 A? Sounds way to high. Computer power supplys put most of the current out on the +5V (3.3). The +- 12 V are much lower current. So most of that power supply is not even being used. Also do you have bad things happening as a result of using a switching power supply? If so, some value of cap could help, but switchers dont like to start reliablly with a lot of capacatance on the output. so you may run into problems. Best idea is to find a linear supply. Can you get your hands on a 15V transformer? That plus a few other parts and you could build your own from scratch.
Good luck; |
#9 | |
60 A for 0.02 sec with 2 V drop is 0.6 F, so significantly less then this is obviously not effective. 22000 uF can assure eg. 4.4 A for 10 ms with 2 V drop, wich is in other words: nothing. |
#10 | |
That is true, and generally a computer PSU is unusable to power a car amp of any kind. The problem is that those 60A is not on a single rail, nor is it all available for the 12V output. You'd normally see 30-40A of that 60A available to the 12V outputs on a 1000W PSU. Much of the available current is reserved for the CPU power only and much is reserved for 3.3/5V output.
If you connect a ½F cap directly on the skinny 12V rail of a computer supply, best case scenario is that nothing happens and the PSU detects a short and shuts down. Worst case scenario is that you'll have a massive meltdown and possible explosion. Quote:
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 07:51 PM |
| How do I connect | drclean | Solid State | 0 | 15th December 2008 06:03 PM |
| Small-signal (or small power) pentode that can handle 400V (or more)? | GordonW | Tubes / Valves | 12 | 13th June 2008 02:07 AM |
| PC-speakers + small amp (key words: small, cheap) | rho | Multi-Way | 8 | 18th May 2006 01:19 PM |
| Page generated in 0.10325 seconds (76.67% PHP - 23.33% MySQL) with 10 queries |
