TDA8920 TDA8924 By Connexelectronic, Opinions Please.
Old 3rd December 2010, 09:59 AM   #51
Cristi is offline Cristi
Banned
Please follow this thread http://www.diyaudio.com/forums/conne...mplifiers.html where i explained the differences. mainly, i named them in the order of development, from a to d, the simplest one is v3a, then v3b which has a better layout, then v3c with speaker protection, rectifier bridge, bigger capacitors, and v3d, with BIPS on board in addition to the features of v3c.
Old 20th December 2010, 09:17 AM   #52
Kjeldsen is offline Kjeldsen  Denmark
Originally Posted by Kjeldsen View Post
I know that most info I can get recommend post-filter (or a combination of feedback as in ICEpower and TC electronics modules), but I also know some who have tried 892X chips, and find the sound more than satisfying - especially in the bass region. Maybe they are hifi for bass purposes? Only a test will show (for me). I will compare with Panasonic SA-XR50.
Interesting info from New Class D who actually recommends pre-filter (who or believe EVA og Lars Clausen)
NewClassD NCDX
"Pre and Post filter mode
Most Class D amplifiers operate in Post filter mode, meaning the feedback signal is taken after the output filter. This gives some advantages like frequency response is not or less dependent on the load impedance, and also in theory lower THD because the distortion of the output filter is compensated by the feedback loop. Other Class D amplifiers operate in Pre filter mode, meaning the feedback signal is taken before the output filter. This has other advantages, like the stability of the loop is not affected by capacitive loads, and the amplifier sounds more open.
NCDX offers you the possibility to chose either of these modes, as the only Class D amplifier on the market. By default it runs in Pre mode, because this usually sounds best, but you can change this simply by moving the solder bubble from the Pre pad to the Post pad. These pads are located close to the output terminals of the board. "
Old 17th February 2013, 02:47 PM   #53
ozracing is offline ozracing  Lithuania
Hi and sorry for bumping this old thread
wanted to ask if someone could share tda8954 HSOP24 library for eagle
Sorry for my imperfect English Best regards
Old 24th February 2013, 08:32 PM   #54
DUG is offline DUG  Canada
Just made one for OrCad.
Close but no cigar.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 5th March 2013, 11:01 AM   #55
stijena1973 is offline stijena1973
The answwer is not so simple: "This is better than that"...
Pre-filter feedback is better for stability, because You avoid one phase shifting stage.. (Remember Nyquist diagram and criterion?).
Post-filter feedback is better if You have a non-linear element in the filter, like saturable core of the output inductance. That way, feedback is going to linearize the transfer function and compensate the non-linearity introduced by the core.
If You want the best of the both worlds, use pre-filter feedback, and air-cored inductor in the output filter. End of story...
Old 7th May 2013, 02:14 PM   #56
Hm, yes, but post filter feedback may lead to instabilities with mismatched load and phase shifts and peaking with all loads... Everything is a compromise.....
Originally Posted by Eva View Post
These ICs use pre-filter feedback and thus they exhibit load dependent high frequency peaking, so I wouldn't consider them very "hi-fi". Otherwise, they include many interesting protections and features.
Old 17th July 2013, 02:34 PM   #57
But you do it below anyway
This it what is done in Lars Clausens designs. The newest versions you can choose between pre and post filter
Old 11th July 2014, 04:02 PM   #58
tiggerlator is offline tiggerlator  United Kingdom
How do i mode switch a 8920bj using pin 23? i need to power on the module to operating mode.
thx
TDA8920 TDA8924 By Connexelectronic, Opinions Please.Hide this!Advertise here!
Connexelectronic TA2022 amplifier with FE167E (94dB/w/m) opinion? lhgin Class D 5 3rd August 2009 05:34 AM
Tda8924 bostjancek Class D 9 26th December 2007 11:12 AM
what about TDA8920? hypnotize Chip Amps 1 27th July 2007 11:26 AM
Selling: TDA8924 (d-class 2x120w) Chaom1 Swap Meet 2 15th November 2006 06:58 PM
tda8924 power supply Chaom1 Class D 0 2nd November 2005 11:42 AM
