| Class D Switching Power Amplifiers and Power D/A conversion |
Hi All,
Names Robbie from RIM Custom Basses in the UK, Im a custom Bass guitar builder. Ive been looking at the amps coming out for bass guitars and at the moment everyone seems to be going into Class D stuff. I would like to try and build a 400/700w bass amp using a 6SN7 Tube preamp/Hypex Ucd 400/700 Power module with SMPS from Hypex also to keep it light. I would like to maybe have a Volume and tone control on the front end to keep it simple. Any info or help on this would be great, as im a newbee to building amps. It looks doable and could be fun Cheers, Robbie. |
#2 |
You're on the right track.
If you go to Hypex.nl and pick the UCD 400 there will be a manual. Read the other thread in this forum about availability of SMPS for it. You will end up with a high power, reliable, lightweight, super low distortion amp. What's the tube for? |
#3 |
I was thinking the valve front end would give it some extra warmth, this company makes there own tube preamp
http://www.lowenddistribution.com/lowendpreamp.htm If not valve could you help me with any other types of preamps with maybe just Volume and tone controls. Cheers, Robbie. |
#4 |
I'm sure that since you hand build custom basses they already have whatever you're looking for in "warmth"
There's an excellent book here: http://www.thatraymond.com/downloads...ttala_v1.0.pdf The author can often be found at: http://www.ssguitar.com/ For bass, I would suggest 6.42 Change the cap values for bass. You could be unique and use a strat type switch. Best of luck, |
#5 |
Im thinking this London Power bass preamp kit could work well,
http://www.londonpower.com/catalog/p...products_id=76 Cheers, Robbie. |
#6 |
Hey Robbie,
I have been working on the same thing for a couple of years. I have got something working for the past few years now and it actually great. I just posted a pic over in the Epifani club on talkbass. |
#7 |
Hi Robbie,
You are absolutely on the right track. For some reason there are no better interfaces for guitar and bass than tubes. The input of the old Vox AC-50 with 12AU7 is one my favourites for bass. But maybe some more Eq-controls are needed. I build guitar-amps(check my profile) but have had the thoughts of this concept for bass. I would then take it on step further with a tube driving the Hypex via an input transformer instead of the OP-amp buffer.
Brgds Lars |
#8 |
Lars, how would you design or buy this transformer for the UCD because the + input has 8k2 impedance and the - input has 1k8 impedance? This is a big difference to overcome.
#9 |
Hi Koifarm,
You have to search(google) the basics of differential amps. I am no pro but this is elementary. Even if it sounds strange the UcD has a Zin of 2*1,8k=3,6k when connected differential. Differential connection is also the best as you should get a better CMRR and no risk of ground loops. So a transformer with lets say 4,5:1 gets a reflected input impedance of over 70kohm at the primaryin the midband. But a 90 H transformer(as in the example below) has an impedance of just above 10kohm at 20Hz There are plenty of transformer out there but I can highly recommend Lundahl. One advantage is that you also get galvanic isolation between Hypex and driver/preamp with a transformer. Below is a theoretical example of a combination that would work with low distortion without tendencies of clipping before a Hypex UcD400 does. The secondary L1 should read 4.4 when connected 4,5:1, though. One could also use a parafeed or balanced configuration.
Brgds Lars |
#10 |
Robbie,
Kevins O´Connors preamp should be good company to the Hypex. Still bypassing the input opamp and adding a tubedriver would be nice. Mail me if you want some help with the design. With a SMPS supply you could travel really light ! The Redrocks supply looks promising. I also use a DC/DC 12V/(up to)210V SMPS for the tube pre. 12V for this and the heaters is available from the Redrocks PSU
Brgds Lars |
| Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A | c10h12n2 | Swap Meet | 7 | 7th July 2007 03:55 PM |
| Light weight (sub)woofer driver? | eRiCdWoNg | Subwoofers | 25 | 1st July 2006 03:06 PM |
| I want to build my own ALL TUBE bass amplifier | juicy1484 | Instruments and Amps | 1 | 2nd November 2005 07:15 AM |
| Light weight speaker system | amirmk | Multi-Way | 5 | 14th November 2004 04:01 AM |
| Page generated in 0.11488 seconds (78.72% PHP - 21.28% MySQL) with 11 queries |
