| Class D Switching Power Amplifiers and Power D/A conversion |
Well hopefully all the knowledgeable people on here can give me some assisstance... I am looking for a class-D chip/chipset that will be able to meet the following requirements.
1) Must not be Tripath - I want to be assured I can buy the chips and if things work out, have a stable supplier. 2) Single supply, in the 24V range. 3) Ideally 40-50W into 8 ohm and stable without issues into 4ohm without changing the power supply of course. 4) High quality is important. I would pay more for quality and will tweak as needed. 5) Analog Input. 6) In keeping with #1, it must be available. I have not done a class-D, but have lots of power supply design and general audio experience so I am not too worried about complexity of implementation and will be doing a full up custom PCB. Any suggestions are of course appreciated. |
#2 | |
#3 |
DOh! Helps if you read what you write. That should have been 40 to 50W into 4ohm, not into 8 ohms.
I am hoping with a 24 volt raise and bridged I can swing withing 2 volts of the rails without much distortion for about 25 watts. Alvaius |
| 1500W RMS Class D PCB - which Class D Driver Chip is it ? | mosfetsound | Class D | 11 | 1st April 2011 11:17 AM |
| class d chip amp | sagarverma | Chip Amps | 19 | 23rd October 2005 05:08 PM |
| new class T chip amp | DJNUBZ | Class D | 1 | 17th October 2005 10:05 AM |
| The ChipSET - A Concept Chip Amplifier | Steve Eddy | Chip Amps | 27 | 26th April 2005 11:42 PM |
| Any Class AB Chip Amps ? | LS | Chip Amps | 1 | 22nd July 2004 08:07 PM |
| Page generated in 0.06995 seconds (79.73% PHP - 20.27% MySQL) with 10 queries |
