| Class D Switching Power Amplifiers and Power D/A conversion |
I'm planning a small household/portable PA system and I'm wondering just how much juice I can put into it without frying a standard household circuit.
In particular I'm looking at the amps + smps from red rocks audio. Say: 2x 750W for mains 1x 1200W for sub = ~2700W How much can household circuits take? The powerboards for sale around here say 10A 2400W.... Thankyou
#2 |
30 Small, 2700W????????
Regards zeoN_Rider |
#3 |
Hehe, the small is in reference to the PA part..... I've been to events advertised as having 50k soundsystems - small is enough for me
#4 |
In my house I have 3 Phase, each phase have fuse 25A.
That is SMALL?! Regards zeoN_Rider |
#5 | |
Isn't the Au system 240V 50Hz AC. with residential breaker limiting to 10A? If that's the case the breaker will trip @ 2400 watts ( approx ). I run a Crown Macro 2400 on a circuit of that capacity. |
#6 |
Average power drawn with full volume music is likely to be around 10% of rated power at best, so no problem.
I use to feel like the small child in The Emperor's New Clothes tale
#7 |
Remember to divide the total maximum peak output with at least 8 and probably 16 because the average level in music is usually recorded at -12db (though some recording companies don't follow this recording standard but I have yet to see any recording with worse than -9db average).
So a standard European household could sustain 240x16x10=38400 watt per phase, so if you have a 3 phase household 115K watt soundsystem is feasible. Just remember not to turn all amps on at the same time. |
#9 | |
#10 |
If you play Chemical Brothers at full volume with 115k watts you would need to be about 20km away
![]() col.
http://www.minirig.org.au |
| DIY Bass Practice Amp Out of Household Items | xsogol | Instruments and Amps | 0 | 3rd February 2009 09:44 PM |
| Amplifiers that not work protection circuit | Hi Speed | Car Audio | 12 | 19th August 2007 04:23 AM |
| DC offset on household ac line ? | percy | Chip Amps | 9 | 24th January 2006 09:30 AM |
| change the SMPS circuit in car amplifiers. + picture | Astro Power | Solid State | 32 | 3rd August 2005 11:35 PM |
| Can this circuit be usefull to audio amplifiers | destroyer X | Solid State | 2 | 27th September 2004 06:47 AM |
| Page generated in 0.08753 seconds (85.58% PHP - 14.42% MySQL) with 10 queries |
