Go Back   Home > Forums > Amplifiers > Class D
Old 2nd January 2009, 11:58 PM   #1
Default Transformer size
I thought about including this in a thread that i already have but my guess is that this might be a good question for others as well. I have been searching all day for information on how to choose the right size transformer for class d. All information i have found is in regards to A or AB.
In my case using the NewClassD modules with 1 PSU. I will be powering 200watt max 89db sensitivity towers.
Old 4th January 2009, 04:42 PM   #2
e_fortier's Avatar
Look at this thread.
Eric
Transformer
Old 4th January 2009, 08:41 PM   #3
eclectic2k's Avatar
in a nutshell, since ClassD is very efficient, you do not have all of the losses involved in A & A/B amps so you do not need to over size the supply so much.
You would do very well with a VA rating ~ the same as your desired output watts.
so say for 200W per channel, two channels = 400W -- a 400VA transformer should do very well.
Looking around at commonly available transformers would seem to recommend aiming for a 500VA model from any of the usual suppliers.
even this is still conservative, since real music and general audio material will not push an amp to more than a few % of it's real rated output very often.
(really 300VA would even be fine, but 500 will give lot's of headroom and a bit stronger supply
-CK
Old 4th January 2009, 08:50 PM   #4
e_fortier's Avatar
Please check these guys out, you can get a 400VA for 44 USD.
I just ordered a few from them.
Antek Xtrm
Eric
Need transformer size recomendation mp006ltk Class D 7 20th November 2006 12:44 AM
SMPS Transformer Size Selection help Workhorse Power Supplies 18 24th November 2005 04:21 AM
Question on transformer size on 6 ohms punchpeanut Chip Amps 1 24th May 2004 07:08 PM
Is this the right size transformer for a LM3875 gainclone? JCoffey Chip Amps 10 29th August 2003 06:25 AM
What size transformer? Rarkov Solid State 16 30th November 2002 03:01 PM
Page generated in 0.07363 seconds (70.92% PHP - 29.08% MySQL) with 10 queries
