Vox T60 60watt amp
Hi
I have a 1960's Vox T60 guitar amplifier, which is humming.
I have disconnected before the OC35 ( No.1 on attached sch)
and the humming stops.
If I reconnect and disconnect at C8 ( No.2 on attached sch) the
humming starts.
I have changed the OC72 with no effect.
Any idea's
Thanks for your time
Ron
humming
there are some reasons for humming when he works:
first of all a bad ground connection,perhaps in the input connectors(clean it with kontakt-spray),or a bad cableconnection(bad soldering point,broken ground connection...).and there could be some electrolytic caps gone weak and old...............
greetings..............
