Soft Start Necessary?
Old 25th December 2008, 09:28 PM   #1
dtaylo3 is offline dtaylo3  United States
Default Soft Start Necessary?
I am going to build a two-channel amp with Hypex 180 modules. I have the two amp modules, the power supply and a great toroid I got from DIYCable.
How necessary and beneficial is the soft start module?
Old 26th December 2008, 07:49 AM   #2
Anthony C Smith is offline Anthony C Smith  United Kingdom
its realy a matter of safety; using soft start allows you to scale the mains fuse correctly, instead of "chucking in a value that doesn't blow"
manufactured product in europe has to comply with EN61000-3-2 (the flicker factor) which limits inrush currents to stop lights flickering, obviously diy is exempt.
the simplest method of inrush suppression is to use an NTC thermisor in line with the torroid, or two in series if the resistance you want is not available in the current rating you need. 10R is a good starting value for the USA, limiting current to 12.5A.
watch out how you mount these though they run hot (thats how the restance drops)
this type of suppression has one drawback, line dropouts do not allow them to cool and the fuse can blow as the mains dips out for a second and comes back!
Anthony C Smith MAES MinstSCE
-I think rain is wet so who am I to Judge-
Old 26th December 2008, 09:05 AM   #3
classdphile is offline classdphile  Antarctica
Account Disabled
You don't have to be concerned with line drop-outs not allowing them to cool, it is likely that they won't be hot to begin with.
Soft Start Necessary?Hide this!Advertise here!
B+ soft start Gluca Tubes / Valves 2 3rd September 2007 01:04 PM
Need a soft start? maxpou Solid State 19 18th April 2007 09:23 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Soft Start your LM3886 jackinnj Chip Amps 4 23rd December 2004 10:50 AM
Copyright ©1999-2017 diyAudio
