T-amp loses one channel, power off/on resets ?
Old 24th December 2008, 09:08 PM   #1
jives11 is offline jives11  United Kingdom
jives11's Avatar
Default T-amp loses one channel, power off/on resets ?
I have a couple of T-amps , and one exhibits a problem that from time to time it loses one channel. however if I turn it on and off at the supply , the channel comes back. I guess it could be the 3.5mm socket, but it seems to be OK, in that when the amp is working, twisting the signal plug makes no difference i.e don't lose the channel.
Anyone come across this ? I'd like to fix it
Old 26th December 2008, 04:51 PM   #2
poopydoopynoopy is offline poopydoopynoopy  United States
poopydoopynoopy's Avatar
Send a message via Yahoo to poopydoopynoopy
Default have audiosource amp seven t with similar issue...
Mine was purchased for $125 and has an issue on startup occasionally.
Left channel does not work til preamp vol gets turned up a bit.
There's a relay board behind speaker terminals that I believe to be the culprit, but I am not sure of that yet as the only problem. Main board has traces slashed everywhere.
Sometimes wrapping on the top of the amp makes it work, sometimes not.
I read of somebody deleting that wretched relay board but can not find specifics on that now.
+1 for help from you vets...
thanks
paul
T-amp loses one channel, power off/on resets ?Hide this!Advertise here!
Sonic Impact T-amp loses one channel jives11 Class D 3 13th February 2009 06:01 PM
Aikido loses power? lazyfly Tubes / Valves 4 20th September 2008 09:07 AM
H-K AVR3000 loses memory among other things Flyier Solid State 13 17th January 2007 12:03 PM
NuForce loses their head designer... kuribo Class D 16 2nd August 2006 07:30 PM
