| Class D Switching Power Amplifiers and Power D/A conversion |
Any one who has a design on a class D amplifier based on opamps ??
#2 |
Hey, i was wondering if it is possible to use som of following components, for a D-class?..
Mosfet: http://docs-europe.electrocomponents...6b8097ae0f.pdf Amplifier for triangle wave and comperating: http://docs-europe.electrocomponents...6b80aa53c6.pdf Possibly this comperator: http://docs-europe.electrocomponents...6b80032b90.pdf Or can i use this as a "all in one": http://docs-europe.electrocomponents...6b80026a9e.pdf i have mosfet drivers an fets.. |
#3 |
You can use almost anything for class D. But why would you choose these? Your MOSFET limits supply voltage to 30 V, wich means approximately 24W @ 4 ohm. If you need only 24W, then there are truly one-chip solutions. And why would you use such an expensive OPA, when a comparator is cheaper and better?
#4 |
very very good, They are can use at D-class amp.
#5 |
what i have calculated i can get around 80-100watt in to 8 ohm at 30V if i use bridge..
30V^2 = 900 900/8ohm = 112.5watt as for the op amp, it is not That expensive.. but what do you want to recommend? |
#6 |
Hmmmm.... I don't think so.
You might squeek by with 50W RMS into 8 ohms with a 30V supply. That's not bad, plenty of power for most jobs. You'll need to keep the chips cool.
Take the Speaker Voltage Test! |
#7 |
okay..
i was thinking of half and full bridge. what is the main factors that i should compare the N - P channel? On resistance, rise/fall time ? and what is the margin max 10% off??.. |
#8 | |
I think IRFZ24N and IRF9Z34N are well enough. I attached a simple schematic. In this circuit your OPA can be quite useful because of its high short circuit current. (But it's just an idea!) You have to change some values! (Gate-resistors and 100 ohm must be reduced significantly if you use AD818.) Take special attention on supply decoupling, and ground plane, if you build it! |
#9 |
Pafi..
I might have explained it wrong, how do i match a N and a P mosfet for a bridge ..the schematic that you made, i guess it is self oscillating?.. i have already made a test breadboard. looks like the pic i attatched, i just need to know, where and how to add "dead time" ?? the op amp i use right now is lm833n, the carrier is around 120khz.. when i connect my 8ohm speaker, it actually sounds great.. |
#10 | ||||
You explained your question well for the first time, but the answer depends on some unknown things, as I said. Don't bother, there are more serious other problems! Quote:
In any cases you must disconnect two gates from each other! And you need level shifting between gate-driver and FETs. Quote:
| Collated Design Criteria/dimensions for Ariel ML-TL Design | talsius | Full Range | 1 | 13th October 2011 05:28 AM |
| Wilson Watt Puppy Clone Design - Design Review Please | soundengine355 | Multi-Way | 8 | 15th August 2008 02:07 PM |
| 4th order bandpass, wheel well design :) (design inside) | TWOJZ | Car Audio | 28 | 13th January 2008 02:56 PM |
| Page generated in 0.10355 seconds (87.01% PHP - 12.99% MySQL) with 11 queries |
