Op amp pwm design
Is it possible ?
Hey, i was wondering if it is possible to use som of following components, for a D-class?.. :smash:
Mosfet:
http://docs-europe.electrocomponents.com/webdocs/097a/0900766b8097ae0f.pdf
Amplifier for triangle wave and comperating:
http://docs-europe.electrocomponents.com/webdocs/0aa5/0900766b80aa53c6.pdf
Possibly this comperator:
http://docs-europe.electrocomponents.com/webdocs/0032/0900766b80032b90.pdf
Or can i use this as a "all in one":
http://docs-europe.electrocomponents.com/webdocs/0026/0900766b80026a9e.pdf
:confused:
i have mosfet drivers an fets..
what is the main factors that i should compare the N - P channel?
It depends on the gate driver, power level, and the quality demand. N an P channel FET's are completely different, so you can't expect too much.
I think IRFZ24N and IRF9Z34N are well enough. I attached a simple schematic. In this circuit your OPA can be quite useful because of its high short circuit current. (But it's just an idea!) You have to change some values! (Gate-resistors and 100 ohm must be reduced significantly if you use AD818.)
Take special attention on supply decoupling, and ground plane, if you build it!
reply..
Pafi..
I might have explained it wrong, how do i match a N and a P mosfet for a bridge :)..
the schematic that you made, i guess it is self oscillating?..
i have already made a test breadboard. looks like the pic i attatched,
i just need to know, where and how to add "dead time" ??
the op amp i use right now is lm833n, the carrier is around 120khz..
when i connect my 8ohm speaker, it actually sounds great..
For a bridge? Why do you think it is different from matching for a half-bridge?
You explained your question well for the first time, but the answer depends on some unknown things, as I said. Don't bother, there are more serious other problems!
Yes.
Between gate-driver and FET, or between comparator and gate-driver if your gate driver has 2 channels. How? R||D, C
In any cases you must disconnect two gates from each other! And you need level shifting between gate-driver and FETs.
Where do you connect it, if power stage is "not yet tested"?
I dont think that matching a half bridge is different to a full bridge..
but shouldn't the N and P have almost same on resistance and same switching times or could all of that be taken care of with feedback?..
how i testet,
i have a "unused" amp in one of the chips so i just made that do the "dirty job" of driving the speaker, i know it is a bad solution, but just to test if it was working, it is clear that the opamp is lacking in current.
matching..
Okay.. thx :D.. so i just have to find some N and P which is as close as possible..
the amp rating and voltage rating does not matter as long at it is greater than the supply voltage and so on..
as for my driver it is only a one channel, is that sufficient?..
and can you link me a easy dead time schematic that i can put in between opa and driver ?..
Re: matching..
Maybe, if you insert two level shifter and two dead-time circuit between gate driver and FETs.
You can't put it there, if you have only one channel of gate-driver! Think it over!
I think first you should learn basics of electronics. Or simply copy a well-designed circuit.
