| Class D Switching Power Amplifiers and Power D/A conversion |
Hello everybody..
I'm new in this forum .. but hope that don't matter ..I know a bit about electronics, and i would like to know a lot more (still under education).. but right now I have set my mind on a diy Class D amplifier, just to make it "easy" I'm going for a sub woofer amp.. the goal of watt??.. hmm around 150-200watts.. there is some things that i would like you to help me with: 1. my switching freq on my test board is 50-100khz and the sound is actually okay considering my audio source is a cheap FM-radio. the oscillator and "comparator" is two LM833. what i used for my triwave is this: http://www.play-hookey.com/analog/tr...generator.html so here it go: 1: at how high freq do you think that i can go to with my LM833 ? 2: why is there a lot of noise in the audio when i plug my speaker to the mosfet driver (i haven tried to make a push-pull stage with mosfets yet), when there is no noticeable noise when i drive my speaker direct from the output of my LM833.. the speaker is a 10watt 8ohm.. hope you can help me ..- any questions, ill do my best to answer.. |
#2 |
any one got some info
#3 |
do you have a complete schematics ?
#4 |
No... i have already made a schematic an put it on a breadboard, working fine at 120kHz.. the only problem rightnow is how to drive my haflbridge or fullbridge..
i have a regulatet +/-7v supply and a +/-24v supply, they share the same 0... |
#5 |
1) driving a speaker directly from LM833 is not a good idea.
2) +- 24V will give you theoretically only 72W RMS (289W in bridgemode) on 4 ohm speaker; and half power on 8 ohm speaker 36W halfbridge, 144W fullbridge). 3) which mosfet driver do you think to use? |
#6 |
The reason i connected the LM833 to the speaker (a small one) was just to tes if it worked..
I'm not totaly sure wich fets im gonna use, but i have a couple of different ones i want to try, just so i find what i think that suits me ..
| subwoofer under bed | Potato42 | Subwoofers | 7 | 13th January 2009 02:21 PM |
| subwoofer project, which subwoofer? | Davlaf | Subwoofers | 12 | 9th November 2006 03:59 AM |
| Subwoofer crossover / subwoofer module design | derMichi | Subwoofers | 4 | 20th April 2006 10:31 AM |
| how to connect a non powered subwoofer to a stereo system without a subwoofer output | JSD777 | Multi-Way | 4 | 20th September 2005 03:19 PM |
| I need help with subwoofer deisign: HUGE inexpensive subwoofer | hottyson | Subwoofers | 16 | 4th May 2004 03:51 AM |
| Page generated in 0.10112 seconds (72.00% PHP - 28.00% MySQL) with 10 queries |
