Go Back   Home > Forums > Amplifiers > Class D
Old 18th December 2008, 02:09 PM   #1
Default Design help needed for IRS2092
Hello All,
I am currently in the planning stages for a 50 watt x 2 channel class d amplifier. This amplifier will be based around the IRS2092 driver IC. I need to add volume and equalizer control, and I am stumped with what IC to use. I originally wanted to use the BA3812L 5 band IC, but I can't find a vendor that will sell small quantities of them. The other chip I was looking at is the TDA1524A, which does volume and tone control.
After digging around the IRF site, I found they used a CS3310 digital volume control IC for one of their application notes. These chips all have different output levels, and I am unsure what will work as a preamp.
Also, I need to build a SMPS to operate this amplifier. I calculated that I need a +/- 35 VDC power supply for 100 watts. I am going to run the amplifier off of 120 VAC from a wall outlet. Does anyone have any suggestions on which type of SMPS to use? Flyback, buck, boost....I am not sure which route to go.
I am looking for all constructive criticism I can get. Any input would be helpful, thanks!
Old 2nd January 2009, 11:06 PM   #2
for smps,use half bridge.
you're going to find some precious information at ir site.
Use unregulated power supply with stiff capacitance at secundary.
IRS2092 customizable DarkOne Class D 27 26th October 2011 08:16 PM
IRS2092 Amp Design: Please help! Devendra Class D 11 17th March 2011 09:10 AM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
Any suggestion for IRS2092 ja2dhc Class D 4 2nd August 2008 10:53 AM
Page generated in 0.07600 seconds (70.65% PHP - 29.35% MySQL) with 10 queries
