Go Back   Home > Forums > Amplifiers > Class D
Old 17th December 2008, 09:05 PM   #1
mickiii is offline mickiii  Denmark
Default Pre-out on the Trends TA-10.1
I am a beginner at this, so please bare with me.
I have just received the Trends TA-10.1, and the reviews are true. It sounds fantastic.
However, because I am using it to power fairly small speakers that does'nt have much bass, I would like to mod a pre-out to it. Is that possible, and if so can someone help with links, guides etc? I can't seem to find anything about it anywhere.
Thanks in advance
Old 17th December 2008, 09:43 PM   #2
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Your source needs to have the current capacity to drive both inputs. Generally, most gear theses days have input buffers that provide a high input impedance of 100K or so, so it's not of much concern to split the output of your source to two separate input circuits.
The power of Science compels you!
Old 17th December 2008, 10:01 PM   #3
Pano is offline Pano  United States
Pano's Avatar
Do you want the volume control on the Trends to control the volume of the "Pre-out"? Or are you using something else for volume control?
Take the Speaker Voltage Test!
Old 17th December 2008, 11:43 PM   #4
Ideally I would be able to control the volume of the preout on the Trend as well. Is that possible?
Old 19th December 2008, 01:04 AM   #5
Pano's Avatar
You can jump out of the trends after the volume pot and before the caps. Right at the jumpers would be the place.
Not the best way to run a sub out, but it can be done and might work OK for you. Having a buffer there should be much better, but it's a lot more work.
Trends for Sale Peter Menting Swap Meet 1 25th April 2008 07:38 PM
FT: Trends Audio TA-10 marginwalker Swap Meet 9 8th August 2007 05:04 PM
Trends ta-10 HELP ( another help thread ) robert1325 Class D 11 30th June 2007 02:50 PM
FT: have Trends 10.1 and looking for Gainclone Jolojl Swap Meet 8 3rd June 2007 02:44 AM
Trends TA-10 problem Theli Class D 21 17th March 2007 05:20 AM
Page generated in 0.09300 seconds (74.85% PHP - 25.15% MySQL) with 10 queries
