Go Back   Home > Forums > Amplifiers > Class D
Old 15th December 2008, 06:23 PM   #11
theAnonymous1's Avatar
Whoa, I was wrong.
A 2Hz sine was able to drive the rail voltage to almost 90V without the over-current protection tripping.
It fried the 150V MOSFETs I had put in. They were working fine with the normal 73V tail voltage, even with a continuous 20Hz sine at almost full volume.
So this is a real problem, even with unregulated supplies. I don't think it is that big of a concern normally as no one in their right mind would let their woofers oscillate at ~2Hz, let alone at any significant volume.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 15th December 2008, 08:58 PM   #12
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Modify the amplifier, use the low frequency cutoff points from the various coupling capacitors to prevent excessive rail pumping.
Try to find a 200V replacement MOSFET with a fast body diode and low charges, even if it comes in another package, for example IRFB4227.
Paralleling more devices is likely to cause trouble due to the gate charge increase.
I use to feel like the small child in The Emperor's New Clothes tale
Old 16th December 2008, 02:57 AM   #13
I have already decided to go with the IRFP4227PBF.
FS: Sprague Powerlytic 36DX 15000 uF 150V Caps likeafox15 Swap Meet 2 7th December 2010 06:55 AM
150V plate output tubes engels Tubes / Valves 10 10th July 2007 05:01 AM
150v 80Khz piezo driver amplifier Dxvideo Chip Amps 21 14th February 2007 12:58 PM
Looking for PHILIPS 50.000uF/125V and 1.900uF/150V ELCO's pantaNS Parts 1 30th November 2005 07:42 PM
Solid state amp on +/-150V ? DJG Solid State 1 12th March 2003 08:46 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
