| Class D Switching Power Amplifiers and Power D/A conversion |
I looked through the FAQ here and saw nothing about the
Swans S3W 2.0 desktop amp for computer and MP3 use. It's like it doesn't exist in these forums-- very hard to find anyone here who is using it, modding it or anything else. Parts Express has it but for this type of electronics there is a lot of questions. Plus I think that the deal cycle at PE will bring them around to a better price. How did Swans, a high end small format speaker maker, get into this? Can the HiVi speakers (that brand was mentioned in some review headers) be modded to a more traditional box build as full range. Has anybody modded the tripath shell to something more traditional? I have not even seen a good enough picture that shows where the volume is. More normal forum reading takes place in Full Range Loudspeakers. |
#2 |
I found the pix of the Swans but also a lot of questions as to how to switch out to a different speaker pair.
http://av123forum.com/showthread.php?t=30829 Any advice appreciated. What is apparently going on here is that the speakers are tethered like an umbilical to the amp. This makes zero sense to me. |
#3 |
I've had a pair of these as my computer speakers for over a year. (I was the 1st to import them to the US).
It's a fun little set. The amp is in the volume control - and yes, it is connected to the speakers buy a cable. The fun thing about these is that they are cheap, and have a Tripath chip amp. A few little mods (new caps) and a better power supply help them a lot. The speakers are nice - no real highs or lows - but what they do have is pleasant enough. The midrange is very good. I enjoy having the volume control right on my desk, kinda like the Griffin USB thing.
Take the Speaker Voltage Test! |
#4 |
frugal-phile(tm)
I have a set of those... any advice on getting the grills off? I was also goint to mod the amp to at least hard wire the cables-- the little t-amp is soooo cute, but the big connectors detract.
Which caps... and just a big *** analog 12V supply (sorta like the kingRex)? dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Well..... I have seen the grills come off, but don't remember how!
Yes, just put a bigger better cap in place of the power cap that is there. Use a 12V supply, too. The ones I got were all 9V.
#6 |
So if you get the grilles off or no is there some sort of effective way to make the pigtails a female end of a connector to hook up some other speaks?
If for instance the wiring had thread in it it would preclude soldering. If the wire is stranded or solid, a female end of a bullet connector or other more refined end could be used. Or a soldered splice would eliminate using too many connectors in the sound path. Since I have my Fostex Fe127e currently running off of a hacked boombox with 3 watts out, I know that even that much juice can run my primary listening setup. Plus I have the FE167e breaking in for a new build project. |
#7 |
Yeah, I got a black one about 8 months ago to use on holiday.
Cool looking little gizmo but very tight in there... like Pano says, change out the power caps. I DC coupled it to my iPod as well with decent input/FB resistors, this seemed to give better base. The only T-amp I've got with a revC TA2024 as well..... and I have a lot, not as many as Pano probably though ![]() I bet Planet10 could come up with a good cab if he could get the drivers out..... what do you think Dave? |
#8 |
frugal-phile(tm)
Thanx for the info Michael,
I was thinking of keeping the same cabs, but tarting up the drivers and box... they'd make a nice mid-tweeter pod sitting on top of some bottom end. dave
#9 | |
Yes they would. =) They really don't go very high, I measured but don't remember. But with some added bass they'd be quite nice.
IIRC, there is still a pile of these sitting at AudioMagus without amps. (Swan's mistake). Don't know if they would be willing to part with them. The one funky thing is the 4 conductor mini-plug used on the speakers. It has to be 4 conductor because, as we know, you can't use a common speaker ground. Not an easy to find connector. Quote:
#10 |
What is the reason for designing four conductor leads?
A reason to put "no user serviceable parts within" on the bottom plate? Like Compaq computers in the old days: a twisted wire on the HD connection so it wouldn't work with anything but OEM parts. Makes me think these jobbies are headed for the closeout deal flier. |
| swans m2 | blue934 | Multi-Way | 0 | 22nd May 2008 05:56 AM |
| Swans M1 DIY Plans and crossover? | EDDIEMUNSTER | Multi-Way | 5 | 8th December 2006 08:20 PM |
| Where to buy swans M20W | billhao | Multi-Way | 0 | 16th August 2006 06:21 AM |
| Swans topmount tweeter | Fox313 | Multi-Way | 2 | 17th May 2006 01:22 PM |
| my new nagaoka swans | lecky | Full Range | 18 | 9th May 2006 03:57 PM |
| Page generated in 0.11892 seconds (81.52% PHP - 18.48% MySQL) with 10 queries |
