Go Back   Home > Forums > Amplifiers > Class D
Old 18th December 2008, 06:06 PM   #41
Default Re: Classd amplifier
Originally posted by ecodoppler
jaydeecee
Thank you for your reply. I have seen the other thread. Really very interesting. I believe that after a long wandering I have found what I need for my Magneplanar. I think I'll order the 300 watts modules and even Canterbury toroidal transformers ( I read positive reviews about them). 300 watts could be enough for my speakers. The only my fear is to receive support from Classd guys.
Ecodoppler
Ecodoppler
I cannot vouch for the 300 watts modules having never heared them but you will require a full power supply for these wereas the 600w have the rectifier and caps on board. I suppose you could use a switch mode power supply for these but that's something that I did not want to do because of RFI issues. The 600w is so simple to connect up that I am sure that you would not need any help from anyone. All you require is a transformer with 0 - 70V and 15v - 0 -15v secondaries. (I use 700V/A transformers one per channel)
Old 18th December 2008, 07:26 PM   #42
Default Classd amplifier
jaydeecee
Ok. Tomorrow I'll ask information to Classd staff. What is the cost of Canterbury Toroidal transfromers? What is the brand of caps?
What do you think about their performance with high/midrange frequencies (voices, strings). In other words, I read that Hypex could have Highs too brittle, harsh for someone.
Thank you
Ecodoppler
Old 18th December 2008, 11:31 PM   #43
jaydeecee
Thank you
Ecodoppler
Ecodoppler
The two Canterbury transformers cost £145/€155
The caps (power supply electrolytics) are standard Samwha, not what you might accept as audiophile caps and I questioned that with Ecotec and they responded that they did not have any degrading audible effect but were chosen for their application/suitability for this Class D design. I can certainly vouch for this fact in how they sound.
The performance of these amplifiers is beyond what you might imagine. They are dynamic when the signal calls for this and have a fantastic soundstage, at no time do they sound brittle. They have no fatigue factor whatsoever. I also have a set of Audio Mirror 6C33C SET tube monoblocks and I tell you I haven't switched them on since firing up the Ecotec Class D amps. To me it's like sitting at a live performance and with the right recordings the hairs on the back of my neck stand up. Voices are natural and the amps dig deep into the recording venues. There is so much more on my CDs that I never imagined was there. Let me say that I have no association with Ecotec Systems and only happened upon them by the chance that another diyAudio member suggested that I take a look at their website. I had no way of knowing how they would sound but ordered blind. It's the best "mistake" I've ever made.
Old 19th December 2008, 06:26 AM   #44
Account Disabled
Originally posted by jaydeecee
If you are referring to the amps that I recommended then I presume that you have listened to them in a hi-end audio system then!
Well I have and I can confirm that they bested a set of Krells driving Wilson Watt/puppies and in my own system they are the best amps that I have heard period.
Yes I was referring to those amplifiers. I needn't hear them in order to quantify them by their own merits, anymore than I need to stick my hand in a flame to know it burns.
It's somewhat less fallacious than having the ability to confirm a third party's, salesman's, "subjective marketing comparison", of how it bested a Krell while not having evaluated the two side by side myself.
Comments such as "There is so much more on my CDs that I never imagined was there" point to the problem. There is only ever what's on the CD, where a good amplifier's job is to add to it gain and as little else as possible, never to show you things that aren't there.
The game in making a truly good amplifier is in maximizing the "as little else as possible" goal, more than the next guy. Proper distortion and measurements are telling of this. To give up on that game and do a 180 implies the inability of being a true contender.
Such marketing is the same old schtick they immediately fall towards when they can't produce a decent amplifier. Simply reinvent reality to suit a product that ignores reality as it is.
A class d amplifier with no feedback is a rediculous notion to the extreme in terms of clean, accurate, and natural "reproduction" of the source. What you end up with instead is every kind of distortion and noise, some of it euphonic in nature, but it's only pleasing in the short duration until you become wise to how it's showing you the exact same things that were missing on every recording. That's to say, how it makes each recording sound identical to the next. Clearly this results more in the taking away from the natural recording rather than enhancing it, which is something that can't be done by an amplifier.
What you have here is an amplifier that's entirely unsuitable for accurate and natural full range audio reproduction. THD is only meaningless in the context they portrayed it, which is a single unknown and very optimal frequency, load, supplies, and generally lab conditions. There is such a thing as meaningful and telling measurements however, and the rest of the industry seems to know this.
I believe you will find that an already high 0.5% THD is the best case outcome and it will only get worse, much worse. You can't honestly expect us to believe that suddenly high distortion sounds good. It's certainly fair, and obvious to say that what they're selling you is distortion and noise, that can be easily mistaken as euphonic until you become aware of it, and in time you will.
To say it bested a krell or any linear, well behaved amplifier just say's you allowed yourself to be taken in by euphony, poor response, and generally blinded to what's really on the source to be experienced. In my experience this is a short term high that's always followed by a hard come down once you come to realize what it is you're missing out on, that which is actually there, for which the distortion and noise is no substitute.
So please keep that in mind as you recommend it to others that might be out to experience true high end sound reproduction from an amplifier that doesn't burry the source in as much euphonic mud as possible and is rather more interested in the long term enjoyment of their investment.
Old 19th December 2008, 06:53 AM   #45
jaydeecee
Thank you for your reply. You are very polite. Actually you seem enthusiastic about this amplifiers. I've seen on their website that they can provide SDV1061-600 evaluation board with 300 W output power on demand; my Magneplanars are 4 ohms load and the builder recommends amplifier with maximum power of 200 watts.
Caps: I imagine the values of power supply caps are very high; in this case it's impossible to use Mundorf or other famous brands (too expensive). One year ago, I replaced the original caps of the Magneplanar's crossover with Ducati energia and Obbligato caps (see Humblehomemadehifi caps test), new woodcase and pure 0.5mm silver wire with teflon sheat. The result is extraordinary: smooth and warm sound.
Yesterday I send an email to Classsd and I'm waiting the reply.
It' s a pleasure to receive advices from you
regards
Ecodoppler
Old 19th December 2008, 08:36 AM   #46
Hello Berns,
I do appreciate your response and understand what you are saying but it is just theory on your part.
I have many years of listening to quality products and as I stated in my previous post I also own a pair of Audio Mirror 6C33C SET tube monoblocks.
Regardless of what you state I still maintain everything that I have said about the Ecotec amps. If you are ever in the UK, rather than in the 3rd stone from the sun, you are welcome to come and experience them first hand.
Regards, John
Old 19th December 2008, 09:02 AM   #47
jaydeecee
regards
Ecodoppler
Ecodoppler
You are very welcome, and yes the SDV1061-600 are the modules that I have.
Regardless of what Berns says in his post I still stand by what I am hearing in my system.
I do realize that we all listen to and like are music in different ways, that is why there are so many different amps, speakers etc. out there so do bear this in mind that this is only my reaction to this product, you must make your own decision on this.
I know that I have been enthusastic about certain kit when having read a rave review but when I have had a demo I have thought it very ordinary.
Regards, John
Old 20th December 2008, 04:50 PM   #48
jaydeecee
I've send three email to Eco Tec systems but I didn't receive reply. Maybe are they closed for Christmas Holiday? Could you help me?
Thank you
Leandro
Old 20th December 2008, 05:19 PM   #49
jaydeecee
Thank you
Leandro
Leandro,
Yes, it is possible that they might well be closed for Christmas. I will phone them on Monday and ask if they have received your mail and then post back on here. Or you could e-mail me on jaydeecee@tiscali.co.uk which might be better than posting here.
John
Old 22nd December 2008, 10:28 AM   #50
fb is offline fb  Australia
Anybody using anything from http://www.redrocksaudio.es./e_main.html?
They have 200W and 1000W amp modules, SMPS and dsp boards, all for very reasonable prices.
FS: Charlize assembled module + power supply dagordon Swap Meet 4 4th March 2008 08:20 PM
Ebay HI-END TA2024 DIY KIT,ASSEMBLED MODULE, anybody tried it? wakibaki Class D 13 10th January 2008 02:49 PM
price/performance speaker cables uzziah Multi-Way 10 8th March 2005 08:36 PM
Page generated in 0.15193 seconds (81.60% PHP - 18.40% MySQL) with 11 queries
