IRS2092 Amp Design: Please help!
Old 17th March 2011, 12:41 AM   #11
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by Devendra View Post
I am trying to make a class-D amp,using IRS2092(S) and IRF6655 for my term here, and I am quite stuck at getting the amp to start working!
Devendra
The irs2092 can be a minefield for those new to class d.
Decoupling is vital, not just around the 2092 but also around the mosfets b+/b- b+/gnd b-/gnd with 100nf. Care must be taken with the 12 volt vcc rail, I had noise on mine causing the 2092 to reset. I used a 100uf on this rail.
I found that I had trouble getting it to run with a 22uH inductor, I found a 30uh worked much better with less resetting on hard clipping.
Just to add to the fun I found some 2092's were susceptible to resetting while others werent even on the same pcb.
I found some got upset with hard clipping inputs and this was cured with a couple of 4v7 zeners across the analogue input.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 17th March 2011, 09:10 AM   #12
luka is offline luka  Slovenia
luka's Avatar
You didn't use RC low pass filter in feedback, I did
Why do you have R18?
Also lower value are recomended for settings of IRS, there has to be some min current going via those resistors, at least 0.5mA for OCSET you have a lot less then that.
You have 45ns dead time, which is fine, but not what you resistors say (measured compared to gnd won't work here)
VAA and VSS can't be more then +/-6v, I used 5.1v zeners, and you have +/-7V (IC could be damaged already)
Vref is 5.1v compared to -Vcc, yours seems to be a lot higher
OCSET being -20V out of -25 V is totaly wrong, 5v is a little less then half of 12V (BTW you really should re-measure everything since most things are compared to -Vcc, like OCSET, Vref, DT,... and some to gnd, as in Vaa and Vss, CSD)
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
IRS2092 Amp Design: Please help!Hide this!Advertise here!
IRS2092 Amplifier zox2003 Class D 24 3rd June 2018 03:30 AM
IRS2092 customizable DarkOne Class D 55 30th July 2014 10:15 PM
IRS2092 on breadboard rob mullen Class D 31 27th November 2010 12:24 AM
Another amp with IRS2092 mag Class D 23 18th June 2010 07:25 PM
Design help needed for IRS2092 cmhadley Class D 1 2nd January 2009 11:06 PM
