Go Back   Home > Forums > Amplifiers > Class D
Old 2nd December 2008, 04:07 PM   #1
dead rat's Avatar
Default How much distortion is too much?
I have simulated my class d amplifier in PSPICE.
20kHz sin signal (yellow) is converted to PWM with:
Green: 400kHz triangular wave.
Red: 200kHz triangular wave.
Purple: 100kHz triangular wave.
excuse my ignorance, but how do i find out how much distortion the sine wave can take before it sounds really crappy?
I would like to know this before i spend hours bringing my amplifier into the real world.
Old 2nd December 2008, 04:50 PM   #2
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
The answer to your question will depend on who you ask, but typically a good THD figure to shoot for is 0.1% or lower at reasonable power levels. How much you can tolerate depends on your ears and whether or not you're trained to listen for it. Obviously, the speaker system used will have a very large part (more so than any decent amp) in this as well.
Brian
Old 2nd December 2008, 06:29 PM   #3
dead rat's Avatar
Is there any equation/tool i can put my faith in, to help me pick the optimal PWM frequency?
Or is this more like trial and error?
Old 2nd December 2008, 07:09 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Residual components above 20Khz are not important, they are usually ignored for THD measurement. You should focus on components below 20Khz. This requires a test frequency below 5Khz or 10Khz.
I use to feel like the small child in The Emperor's New Clothes tale
Old 3rd December 2008, 07:42 AM   #5
Gyula is offline Gyula  Hungary
Gyula's Avatar
Send a message via Yahoo to Gyula
As long as your speakers are linear. But nothing is linear in reality. The sidebands around the carrier harmonics are also infinite, so they can be above the noise floor in the audible range. It depends on the carrier and the audio frequency.
How to get the less distortion with BJT? dododio Solid State 24 6th September 2008 09:55 AM
Neo 8 distortion? studiotech Multi-Way 4 17th April 2005 05:22 PM
Non Linear Distortion testing - Harmonic Distortion JMB Multi-Way 0 20th July 2004 02:54 PM
op amp distortion zahlm Parts 3 15th May 2004 07:45 PM
Page generated in 0.08437 seconds (71.42% PHP - 28.58% MySQL) with 11 queries
