Go Back   Home > Forums > Amplifiers > Class D
Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 16th November 2008, 03:33 PM   #1
Greg911 is offline Greg911
Default Replacement amp for A-Bus?
Very much a newbie here with a question about my A-Bus home audio system. Not even sure if this is the right forum to be asking this question...
Currently have in wall amps/keypads, powered from a 24 volt supply over cat 5 wiring. Not even sure what type of amps these are, except they produce very little power and lots of heat. I'm familiar with the Sonic T-Amp, and wonderd if this type of amp would be a good replacement- would it be possible to get more power and less heat with a different amp? I'm limited to powering this with 24 ga cat5 wiring (although I could tie two pairs of wire together ~21 gauge), and the size must fit within a standard wall switch box. Obviously not looking for anything with a lot of power, just enough to provide clean background music through 8" Polk speakers (90 db efficiency)
Any suggestions? I'd be interested in an assembled amp or kit.
Greg
Thread Tools
Replacement LED DreadPirate Parts 11 14th November 2009 05:45 PM
MTX 5 ch pot replacement pk386 Parts 2 1st October 2006 05:32 AM
replacement cap for T-amp: How big? MEXXX Class D 5 10th December 2004 01:30 PM
Replacement for 5R4 Ralph Tubes / Valves 8 16th December 2003 11:02 AM
Page generated in 0.10734892 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
