Go Back   Home > Forums > Amplifiers > Class D
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 9th November 2008, 10:07 AM   #1
Default Simplest class D ever
Being almost new to class D, I would be happy to find the simplest possible circuit evere to start with. Preferrably a discrete one so I can see how it works. I searched and found a few suggestions, but they all seemed a bit too complex to start with. Of course, I could try developing something myself, but I reckon somebody here has a thing or two finished already. My intention is to use it as a subwoofer amp, so distorsion and bandwidht are not critical. High power would be nice though....
Thanks in advance!
Old 9th November 2008, 04:39 PM   #2
BWRX is offline BWRX
diyAudio Moderator Emeritus
You could use a 555 timer to generate a PWM signal for an integrated output stage.
Brian
Old 9th November 2008, 06:41 PM   #3
Absolutely, or an OP. Just need some drivers and output devices to beef up the power. 500 watts peak would be perfect.
What do you think of IRF540/9540 ? Fast enough? Or perhaps IRFP240/9240, they can take up to 80 amps of surge current. And if 90% efficiency can be reached, that will only produce 50 watts of heat at full power.
Maybe I should start drawing something in EW.
Old 9th November 2008, 08:09 PM   #4
TI's TAS5261 is a high output power, open loop integrated gate driver and output stage in a PSOP36 package. All you need to do is feed it a PWM signal. Or you could certainly use a driver chip and your own discrete output devices.
Brian
Thread Tools
simplest sub amp odysseybmx414 Solid State 2 28th December 2005 05:24 AM
The Simplest Pre-Amp MPW Solid State 76 5th November 2005 01:47 AM
Simplest class B Amplifier PicancoNet Solid State 42 8th June 2005 03:55 PM
Simplest possible Mr. Triatic Solid State 7 17th October 2002 10:11 AM
Page generated in 0.06676197 seconds (75.22% PHP - 24.78% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
