Go Back   Home > Forums > Amplifiers > Class D
Old 4th November 2008, 07:52 PM   #1
sts9fan is offline sts9fan  United States
Default Safety GND question Amp6 basic
I just put together a amp6 basic. It uses a wall wart and a round dc plug. Is it possible to ground the chassis or should i not worry about it? i guess i should at least get plastic standoffs.
Old 4th November 2008, 08:16 PM   #2
albin is offline albin  United Kingdom
Default safety earth,not sure
Good question.Do you have 3 pin plugs in USof A .wire a seperate earth wire to a pin & plug it in to the wall,connect to chassis.Anyone else correct me.important stuff.
Old 4th November 2008, 08:16 PM   #3
infinia is offline infinia  United States
infinia's Avatar
As long as the wall wart has safety markings i.e. UL CSA etc, and is under 24V (SELV) your good to go. An input fuse would be a good idea anyway.
Ground is mainly provided for safety. If you have EMI RFI, ground loops, then a good filtered barrier strip might be an idea.
edit> hopefully the DC input has some EMI filter/s on the amp?
Switching amps are sources of noise so conn to grounds would make other things worse, unless you have very elaborate real earth grounds.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 4th November 2008, 10:55 PM   #4
Saturnus's Avatar
We're talking very low voltages here, around 12 volts, so it really doesn't matter. The AMP 6 BASIC has an input fuse already on the board, and there's basically no way you can damage them if you soldered everything in right.
Sturdy little buggers. I used mine on festivals where you in the mornings could see dew dripping off the board it was so damp, and the sound was still perfect.
Suitable as an Amp6-Basic PS? revans Parts 0 5th July 2009 02:19 AM
Buzz from Amp6-Basic revans Class D 15 22nd February 2009 12:09 AM
Quick Amp6-Basic Question revans Class D 2 2nd August 2008 04:12 AM
Amp6 Basic PSU cap question johnm Class D 14 5th June 2007 06:43 PM
Amp6 Basic Dennis Hui Class D 10 27th September 2006 02:27 AM
Page generated in 0.06165 seconds (82.20% PHP - 17.80% MySQL) with 10 queries
