| Class D Switching Power Amplifiers and Power D/A conversion |
#21 | |
http://www.zetex.com/audio/audio06.asp Their latest measured results show around 120dB dynamic range at the speaker outputs, which rivals the best standalone DACs (which then have added noise and distortion from power amplifier stages etc) http://www.zetex.com/audio/audio06_4.asp Unfortunately the chips (and any design support) are only available to OEMs as far as I'm aware :-( http://www.zetex.com/audio/audio06_2.asp Ian P.S. Disclosure -- I don't work for Zetex, but I did design the ZXCZM800 clock and PWM modulator output stages which would limit the dynamic range if they had jitter of more than a few picoseconds :-) |
#22 | |
No one is stopping you or anyone else from discussing other designs, and you are free to skip any lame Tripath threads or posts. Maybe the class-d elites here should start their own forum where they are free to heckle and ban people with less knowledge.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#23 | |
I still regard myself as a learner in Class-D field, not an elite..........but i love to take part in discussions involving non-T-amps & non-UCD amps...
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
#24 | |
Class D is analogue if you start with an analogue signal and then make a PWM via triangle+comparator or by hysteresis selfresonance or by UCD. Because in all this constellations you start with analogue and code the information in a PWM which allows any duty cycle values - without quantization steps. The information remains 100% analogue. If you go through a signal processor and generate a digitalized PWM with quantization steps for your power switches, then I would tend to call it digital - even if there is usually something like a passive power DAC in the end of the chain, formed by the output filter and the speaker. What is better? Good question. But I would also guess that digital-analogue-digital-analogue is not straight forward and might cause more damage to the signal than a chain with less conversions. If we compare: Digital-analogue and staying analogue with traditional class D designs. Versus Digital-into a digital class D and convert to analogue in the passive end stage.... Then I would guess it will end up in the question of how good the chosen digital coding & filtering + D-A conversion of each system and output filter are fitting together. I am sure you can mess up both ways. In fact most of our music, which we hear, is already digitzied with quantization steps and quite poor sampling rate.... And with respect to the catastrophic appearing CD standard, I am again and again wondering how well our ears do accept it. |
#25 | |
Well Ian, if you find out which other products uses it, maybe we can get hold of one and modify it.... |
#26 |
Well the Apogee DDX chips look interesting.
The power chips can even be driven by Tripath controllers, if you want analog input. Otherwise the Apogee DDX control chips sure have a ton of features. It's all going to end up as variable duty square wave that gets low pass filtered on its way to the loudspeaker - but how you get to that square wave is the interesting part. The digital path up to that point "should" have some advantages. But of course you have to deal wit the volume control, for better of for worse.
Take the Speaker Voltage Test! |
#27 | |
NAD are presumably a flagship DDFA user to gain market acceptance of DDFA as a high-quality class-D amplifier, though I guess they're not exactly small volume. I believe Zetex are primarily targeting the high-volume Far East audio manufacturers in markets like home cinema, because this is where the big production volumes are and Zetex want to sell lots of chips (which would make us happy too since we manufacture them :-) So I guess whatever product NAD come out with is likely to be the best candidate for class D/audiophile modding -- unless you want to try and reverse engineer a multichannel Chinese-sourced home cinema box... Ian |
#28 |
I just wonder why nobody talks about the texas chips
#29 | |
Or the D2Audio approach: http://www.d2audio.com/ Steven
The Analog Art shows no sign of yielding to the Dodo's fate. The emergence and maturation of monolithic processing finesse has perhaps lagged a bit behind the growth of the Binary Business. But whereas digital precision is forever bounded by bits, there is no limit excepting Universal Hiss to the ultimate accuracy and functional variety of simple analog circuits. - Barry Gilbert, 1973 |
#30 | |
The unfortunate thing, I believeabout fully digital system is, quite frequently they require you to have some sort of support chips to generate the volume control, remember the last setting of the volume control , booting up the system etc. There must be a reason for them to have so many legs.... So I would not probably do it unless there is a full kit or modify a preexisting set., since i know nuts about digital....Oon |
| Fully digital crossover | Bitstrom | Digital Line Level | 25 | 5th August 2009 01:07 AM |
| Fs : Pga2311 Fully Digital Preamp | ANADIGIT | Swap Meet | 0 | 14th June 2009 04:02 AM |
| Has anyone experienced fully digital power amps? | soongsc | Digital Source | 12 | 22nd April 2005 01:37 PM |
| Fully Digital Power Amp? | soongsc | Solid State | 0 | 5th April 2005 03:01 AM |
| Is fully digital amp = Non Oversampling Power Dac? | jkeny | Class D | 1 | 1st February 2005 12:52 PM |
