Go Back   Home > Forums > Amplifiers > Class D
Old 31st October 2008, 07:47 AM   #1
atldiyr is offline atldiyr  United States
Default T Amp speaker cables
I'm using a T-Amp in a portable audio application and was deciding on what to use for speaker connections. I'm thinking that 22 AWG, solid conductor, radio shack speaker wire might be suitable for a length of approx. 1 ft. I've got some home depot speaker wire which silver and copper stranded, but I really don't even know if this actual copper or not. It probably doesn't matter for such a short length but thought I would get an outside opinion anyway.
Old 31st October 2008, 03:19 PM   #2
I don't necessarily want to speak for everyone, but the general consensus around here seems to be that for short runs, it doesn't matter all that much. In longer runs and at higher power, the gauge of the wire does apparently start to make a difference.
The Home Depot wire is certainly copper. Most likely the silver-colored wire is tin-plated, just for the purposes of telling which wire is which.
--Buckapound
Old 31st October 2008, 07:31 PM   #3
Pano is offline Pano  United States
Pano's Avatar
I agree with Buck.
Take the Speaker Voltage Test!
Old 1st November 2008, 01:03 AM   #4
Thanks - I thought it was copper. I appreciate the feedback.
Old 27th November 2008, 01:37 AM   #5
EdT is offline EdT  Canada
go with 16awg, it can't hurt !
Old 27th November 2008, 01:22 PM   #6
rhing is offline rhing  United States
rhing's Avatar
Default Try the Walmart Yard Master patio extension cord
The 16AWG PVC-insulated Copper Woods Yard Master Patio Cord from Walmart mentioned here:
http://www.6moons.com/audioreviews/w...moonshine.html
has worked wonderfully well with the SI Gen 2 T-amp and the modified Sure Electronics TA2024 T-amp that I have. Just make sure you find the package of white-colored cable that is identical to the one pictured in the article. 40 ft. cost me about $8.75. The Multi-Contact LS4 banana plugs are nice low mass connectors. A good source for a set was Audio Magus:
http://www.audio-magus.com/product_p/mcls4.htm
I was skeptical at first about this cable, but I noticed improvements soon after installed them in my system. With some frequency response measurements, I was able to verify that I was getting better frequency extension at the low and high ends. These cables may not be for everybody, but they have been working well for me.
Rich
Old 30th November 2008, 06:54 AM   #7
Thanks for the recommendation, it's interesting finding out simple things which can make a difference.
Old 30th November 2008, 04:20 PM   #8
Speedskater's Avatar
I would just go to a discount/closeout store and buy an everyday AC extension cord and cut both connectors off.
Kevin
Old 30th November 2008, 04:53 PM   #9
Pano's Avatar
Default Re: Try the Walmart Yard Master patio extension cord
Yep, I do that all the time.
I've used them both - they work.
F1 or F2 with MIT speaker cables? roscoeiii Pass Labs 1 13th July 2009 01:47 AM
Your Speaker Cables... jleaman Multi-Way 41 17th May 2006 03:29 AM
cables for diy amps, preamps, and speaker cables ... paulspencer Solid State 5 3rd August 2004 08:14 AM
can I use OFC speaker cables jarthel Tubes / Valves 17 10th June 2003 10:03 PM
Page generated in 0.08989 seconds (81.05% PHP - 18.95% MySQL) with 10 queries
