| Class D Switching Power Amplifiers and Power D/A conversion |
bad news....
![]() so i hooked up my t-amp pushing a whole 6 watts into my kabuki kenwood kl777a's the in put was from my mackie where i pumped some vocals, bass guitar, reg. guitar.... and boy howdy it was loud!!!! i pushed the amp so hard! then.... when i hooked my t-amp back up to my minimus 7's one channel is clipping and significantly lower in volume and scratchy.... i think i killed my t-amp.... pictures of board are POST incident |
#2 |
Here are some higher quality pics;
http://www.superiorvideoauctions.com/ak/ak1.jpg http://www.superiorvideoauctions.com/ak/ak2.jpg http://www.superiorvideoauctions.com/ak/ak3.jpg http://www.superiorvideoauctions.com/ak/ak4.jpg http://www.superiorvideoauctions.com/ak/ak5.jpg http://www.superiorvideoauctions.com/ak/ak6.jpg |
#3 |
bmp
#4 |
killed?
yes, it looks dead
lineup |
#5 | |
there's nothing i can do?? |
#6 |
does no one know anything about why this has happened? cmon i took pictures and everything!!!
#7 |
sorry to patronise.
#8 |
check also input and output connectors.
check all cables try to change inputs-outputs (R channel with L channel) |
#9 |
yeah, i checked the speaker
the thing is when i put any power into the left channel it starts cutting out... like a protection cutout.... at very low levels i get audio, but fuzz, when i turn it up at all then it starts clipping and cutting out BOTH channels not just the left, sdo it must be the amp rather than the speakers. Don't tell me i'm the ONLY one that has had this problem?? |
#10 |
Hi there Tyler, seems you killed it.... happens sometimes,
I can ofrouce try to get some IC's here, but then i have to buy atleast 100 pieces and they cost around 23 RMB here. I can also sell you a replacment board, for 50 RMB. probably worth the trouble , you then just can replace the input caps with the ones from the old board, if you want more juice, i also can help you with a TA2020 Board, that one is much stronger and can take a beating! the IC itself is 3 times bigger than the TA2024 so the heat dissipation is not an issue. if i can help, just let me know. Greetings from Shenzhen, Arjen Helder
Always check the power supply... and my spelling... |
| Help Please. I think I blew my toroidals | snknby123 | Chip Amps | 20 | 19th January 2009 08:49 PM |
| Fuse blew | markiemrboo | Chip Amps | 30 | 21st November 2006 04:40 PM |
| Help. I blew up my amps... | ptwining | Class D | 5 | 15th April 2006 02:57 AM |
| Blew my transformer | rs1026 | Chip Amps | 17 | 17th August 2004 12:50 AM |
| Page generated in 0.12547 seconds (72.66% PHP - 27.34% MySQL) with 11 queries |
