Go Back   Home > Forums > Amplifiers > Class D
Old 16th October 2008, 06:48 AM   #1
Default Behringer Pmx660m Power Amp Help
Hi everybody! Please i need help of yours. I´ll appreciate you colaboration. Sory my english is nt good. I´ve a PMX660M powered mixer, the power supply and power amp has failed, i suuspect of a mains fail (in the power supply, caps and transistors are blown, in the power amp, one of two channel blown the MOSFET and resistances). Has been repaired and operational, but:
When load is connected, the FBQ leds blinking without control, and the power amp is shutdown before to reach the maxium level output. While happen this, just before shutdown, the audio is distorted, generating audible "peaks" in the speakers. In the oscilloscope, i see the peak, the signal raises instantly to +V. Below of this peaks, the audio is perfecly clear and no distortion.
Two things: 1) when the mixer section is powered by another external power supply, the FBQ led are steady ok or working well.
2) i´ve tested with main and monitor output to load other amp and work ok without problems. For this i´m discarted the mixer section for this problem.
I have, tanks to this wonderful forum, the complete schematics of the circuits (SPS400 power supply and DPA300 power amp) , but i need help, i´m checking the components and all are ok. Only the main IC on the power amp (HCA4001) is not tested yet, but, all voltages in this are nominal.
What can be this problem? SOmebody has experienced with this modules?
I´m very appreciate you help!
Regards for everyone from Argentina!
Gabriel.
Behringer A500 power amp problem, please help? emperor Solid State 34 8th December 2010 10:42 AM
FT: Behringer EP-2500 Power amp saabracer23 Swap Meet 0 25th March 2008 12:39 AM
Behringer MX9000 - odd power issue Deekaph Power Supplies 23 11th March 2008 04:16 PM
behringer dcx2496 buzzing from power inverter zbomb5610 Digital Line Level 2 27th March 2004 02:25 AM
Page generated in 0.06909 seconds (66.92% PHP - 33.08% MySQL) with 10 queries
